jchaussee Member
Posted: Wed Aug 17, 2011 6:03 pm Post subject: Head Gasket |
| So I have been having an issue with my radiator building a lot of pressure and being a little foamy on top. So I assumed head gaskets. Well I did compression test today and all cylinders were withen 10 psi. So should I assume head gaskets are fine. |
Posted: Wed Aug 17, 2011 6:12 pm Post subject: |
Only way to know is to remove the spark plugs, and pressure test the cooling system. See if the pressure drops, or stays. Or use some combustion testing dye in a sample of the coolant to see if combustion gas is entering there.
Compression tests are really worthless. _________________ A redline a day keeps the carbon away! |
jchaussee Member
Posted: Wed Aug 17, 2011 6:20 pm Post subject: |
| At Oriellys they have a radiator pressure testing tool. Think that works?? Also where can I get this dye you speak of. And besides head gaskets, where else could air get in at |
MrMike98 Member
Posted: Wed Aug 17, 2011 6:36 pm Post subject: |
try takeing a coolant sample to ur local radiator shop, they can run a quick check for combustion products in that coolant...
just anouther method, |
izcain 9sec Club
Posted: Sat Aug 20, 2011 8:14 pm Post subject: |
A cylinder leak down test may reveal some clues as well. _________________
9.17 @ 148 |
jchaussee Member
Posted: Sat Aug 20, 2011 8:17 pm Post subject: |
| I don't know how to do leakdown test. I am going to try chemical test first. Would a leaking exuast manifold let gas into cooling system?? |
Posted: Sat Aug 20, 2011 8:18 pm Post subject: |
| jchaussee wrote: | | Would a leaking exuast manifold let gas into cooling system?? |
No.
Compression to coolant leak is head gasket, cracked head, cracked block. |
jchaussee Member
Posted: Sat Aug 20, 2011 8:24 pm Post subject: |
| With my compression numbers being so close, and the fact I have 882 heads, would it be a decent assumption that heads have small cracks. I am not showing any of the other signs of broken head gasket such as overheating, coolent in oil or smelly exaust |
Posted: Sat Aug 20, 2011 8:36 pm Post subject: |
How do you know it's building excess pressure? _________________
jchaussee Member
Posted: Sat Aug 20, 2011 8:40 pm Post subject: |
| Cause it gets a lot of small bubbles ( foam) it the radiator, also when I start it instead of it flowing nice is just starts spewing out radiator ( if I have cap off) |
