Selling off some parts...
PostPosted: Fri Mar 09, 2012 10:03 pm    Post subject: Selling off some parts... Reply with quote
I'll probably update this as I yank stuff off the bird... Dewey made quick work of the exhaust off my LS. Laughing I'm not sure what any of it is worth because I'm a bit lazy to do my own research. Very Happy If I'm unreasonable, let me know!
For now I have;
stock LS6 injectors (28lb-30lb depending on the source); $100
trimmed sportline springs; $100
PostPosted: Sat Mar 10, 2012 5:55 pm    Post subject: Reply with quote
Parting the whole bird out, or have another trick up your sleeve?
PostPosted: Sat Mar 10, 2012 7:02 pm    Post subject: Reply with quote
Oh I'm definitely not parting it! Laughing Just the stuff I'm pulling off to get the turbo and associated junk on the car.
jchaussee
PostPosted: Sun Mar 18, 2012 11:56 am    Post subject: Reply with quote
Would the springs improve the ride?
PostPosted: Sun Mar 18, 2012 2:00 pm    Post subject: Reply with quote
Saw this after responding to your other post. No, for the general public the ride would probably get worse. It's going to be stiffer and much lower so you'll have to pay attention to approach an departure angles, ruts in the road/etc.
jchaussee
PostPosted: Sun Mar 18, 2012 2:47 pm    Post subject: Reply with quote
Right now I have 27 year old z28 springs with a coil cut out. So if they would be an improvement to that, I may be interested
jchaussee
PostPosted: Tue Mar 20, 2012 4:35 pm    Post subject: Reply with quote
How much are they trimmed. I run 235/60/15s so if they would fit id be interested.
PostPosted: Tue Mar 20, 2012 8:44 pm    Post subject: Reply with quote
It's been awhile since I cut them. I want to say a 1/3 of coil in the front and a 1/4 coil in the rear? Your tires are ~.4" taller than my front and ~.9" shorter than my rear tire. The only time I rub is full lock in reverse.
