		| Author | Message |
		| iansane Member
 1991  Pontiac  Trans Am
				|  Posted: Fri Mar 09, 2012 10:03 pm    Post subject: Selling off some parts... |   |
				| I'll probably update this as I yank stuff off the bird... Dewey made quick work of the exhaust off my LS.  I'm not sure what any of it is worth because I'm a bit lazy to do my own research.  If I'm unreasonable, let me know!
 For now I have;
 stock LS6 injectors (28lb-30lb depending on the source); $100
 trimmed sportline springs; $100
		| Back to top |  |
		| 91RSVert Member
 1991  Chevrolet  Camaro RS
				|  Posted: Sat Mar 10, 2012 5:55 pm    Post subject: |   |
				| Parting the whole bird out, or have another trick up your sleeve? |  |
		| Back to top |  |
		| iansane Member
				|  Posted: Sat Mar 10, 2012 7:02 pm    Post subject: |   |
				| Oh I'm definitely not parting it!  Just the stuff I'm pulling off to get the turbo and associated junk on the car. _________________
		| Back to top |  |
		| jchaussee Member
				|  Posted: Sun Mar 18, 2012 11:56 am    Post subject: |   |
				| Would the springs improve the ride? |  |
		| Back to top |  |
		| iansane Member
				|  Posted: Sun Mar 18, 2012 2:00 pm    Post subject: |   |
				| Saw this after responding to your other post. No, for the general public the ride would probably get worse. It's going to be stiffer and much lower so you'll have to pay attention to approach an departure angles, ruts in the road/etc. _________________
		| Back to top |  |
		| jchaussee Member
				|  Posted: Sun Mar 18, 2012 2:47 pm    Post subject: |   |
				| Right now I have 27 year old z28 springs with a coil cut out. So if they would be an improvement to that, I may be interested |  |
		| Back to top |  |
		| jchaussee Member
				|  Posted: Tue Mar 20, 2012 4:35 pm    Post subject: |   |
				| How much are they trimmed. I run 235/60/15s so if they would fit id be interested. |  |
		| Back to top |  |
		| iansane Member
				|  Posted: Tue Mar 20, 2012 8:44 pm    Post subject: |   |
				| It's been awhile since I cut them. I want to say a 1/3 of coil in the front and a 1/4 coil in the rear? Your tires are ~.4" taller than my front and ~.9" shorter than my rear tire. The only time I rub is full lock in reverse. _________________
		| Back to top |  |
