Is this the greatest thing ever?
Goto page 1, 2, 3  Next
PostPosted: Sat Oct 29, 2011 8:32 pm    Post subject: Is this the greatest thing ever? Reply with quote
http://www.theturboforums.com/smf/index.php?topic=151792
Note the windshield banner and professional airbag/weight jack system in the rear. Cool
jchaussee
PostPosted: Sat Oct 29, 2011 9:45 pm    Post subject: Reply with quote
Thats awesome. The footballs are great
PostPosted: Sat Oct 29, 2011 10:31 pm    Post subject: Reply with quote
Gotta love it. Remember that firebird article where the guy boosted junk yard motors? Kept going through them until he found one that didnt blow. Lol.
jchaussee
PostPosted: Mon Oct 31, 2011 9:11 am    Post subject: Reply with quote
Looking at this inspires me. How much of a budget do you think I would need to add twin turbos to,my car?
PostPosted: Mon Oct 31, 2011 4:16 pm    Post subject: Reply with quote
If we ever get finished putting a single turbo on my car I'll tell you. Laughing
PostPosted: Mon Oct 31, 2011 4:33 pm    Post subject: Reply with quote
You got the water pump junk prepped and ready?
Turbo Drain fitting and hole in oil pan?
jchaussee
PostPosted: Mon Oct 31, 2011 4:37 pm    Post subject: Reply with quote
I got this nieghbor kid who has done alot with import turbos, and he seems to think that if we do all the piping ourselves that would should be under a grand including the carb, but I am not sure. I habe been doing alot of reading on tgo, but most are on FI cars
PostPosted: Mon Oct 31, 2011 4:58 pm    Post subject: Reply with quote
Pump yes, junk always, pan no. Laughing
PostPosted: Mon Oct 31, 2011 5:48 pm    Post subject: Reply with quote
You'll be way over a grand.
jchaussee
PostPosted: Mon Oct 31, 2011 7:40 pm    Post subject: Reply with quote
Ya. I have been looking for parts on cl. Depending on piping, it may be close?
PostPosted: Mon Oct 31, 2011 7:53 pm    Post subject: Reply with quote
I guess it depends on how back yard engineered you're going and how often you want to be stranded.
PostPosted: Mon Oct 31, 2011 7:55 pm    Post subject: Reply with quote
Never had any luck finding turbo parts on CL. All eBay trash and ricer stuff.
PostPosted: Mon Oct 31, 2011 7:56 pm    Post subject: Reply with quote
Off the top of my head:
$100 fuel pump
$150 regulator
$400 boost prepped carb
$xxx Tuning costs (Let's face it, you aren't there)
$200 braided fuel line
$200 fuel line fittings
$200 carb hat
$200 min for mild steel piping (Rust is always good in your intake) or
$350 min for stainless piping
$xxx welding the mild steel piping
$xxx welding the stainless piping
$200-500 exhaust system
$500 min for a pair of good turbos
$150 min cl intercooler
$125 couplers for the charge piping
$250+ for turbo manifolds
Comes out to $2675 if found cheap, plus the cost of fabing the piping on the cheap.
Good luck with that $1000.
And don't forget a pair of wastegates and blow off valves!
Oh and a turbo drain and feed line and welded fitting in the pan, easy $200 there.
Oh yeah, and your cast pistons will look really nice in the bottom of the pan. : O )
PostPosted: Mon Oct 31, 2011 8:00 pm    Post subject: Reply with quote
Ha ha
Probably a $1k in just little shizzle you dont even think about. Thats how these projects always seem to work. Sad
PostPosted: Mon Oct 31, 2011 8:05 pm    Post subject: Reply with quote
For what it's worth:
I'm a guy who for a long time built crappy sh** on the cheap. On my later projects I've become a guy who plans to do everything right and ends up with a half finished project for lack of funding, but that's okay because I'd rather have a roller than a turd. Wink
As for your thousand bucks, think about this: I will probably spend more than that on an intercooler, wastegate and blowoff valve. Just three items and I've killed your entire budget. Laughing
jchaussee
PostPosted: Mon Oct 31, 2011 9:23 pm    Post subject: Reply with quote
Ya. May seem a little far fetched. I will still do my best. I was thinking of using ford turbos.
jchaussee
PostPosted: Tue Nov 01, 2011 12:42 pm    Post subject: Reply with quote
So as I was going through the list of parts amd costs which paul providedbme, and I appreciate, I still think that I can come close to it maybe more like 1500, and my reasoning for that is that in my quest for more power, I needed alot of stuff anyways such as exaust, headers, better fuel pump, better heads etc. so many of the costs I will have either way. So with that said, I am hoping with turbo specific parts I will only be spending 1500 or so more then I I will normallybto get more power. Which I will need to decide which way I will go. Twin turbo, or build my 327 as much as can.
jchaussee
PostPosted: Tue Nov 01, 2011 2:59 pm    Post subject: Reply with quote
Well I did somemore reading today. I suppose I could go cheap and blow motor, which probably wouldnt bother me too much, or I could do it right and build motor so it could handle 8 to 10lbs boost. That is the path I think I will go. I will redo all that needs to be done to handle a reliable 400 or so horsepower motor, get motor to that point, then decide if then I want to tt it.
PostPosted: Tue Nov 01, 2011 5:50 pm    Post subject: Reply with quote
slightly edited for content. Let's keep our membership in mind when we post gents.
Thanks,
PostPosted: Tue Nov 01, 2011 8:31 pm    Post subject: Reply with quote
Classic MRA. Wink
Page 1 of 3
