Bilstein or Koni?
PostPosted: Thu May 05, 2011 9:43 pm    Post subject: Bilstein or Koni? Reply with quote
My shocks/struts have probably ~100k on them and at least one offroading adventure. I was inspecting the passenger side one when I did my strut mounts and it was leaking just a bit. I have bilstein HDs right now but I'm not sure what I should run next. I'm kind of leaning towards the Konis just to try something different?
PostPosted: Thu May 05, 2011 9:52 pm    Post subject: Reply with quote
You can't go wrong with Koni. It sucks that the front strut options are so limited. The UE valved rear bilstein-pro's would be awresome, but I don't think their is anything out there to match them for the front end.
I vote Koni. Or get a hold of your mom's Amex, and start calling some serious race shops.
PostPosted: Thu May 05, 2011 10:05 pm    Post subject: Reply with quote
Good idea! Alright, I should change the title to "Moton, Ohlins or Pfadt?" Laughing
Either direction I go I'm going to keep the Bilstein shells around for re-valving down the road so maybe I should go with Koni.
PostPosted: Thu May 05, 2011 10:28 pm    Post subject: Reply with quote
I am pretty sure Penske makes a strut body, it would just be a matter of getting the right size to somehow fit "into" your bilstein strut housing.
PostPosted: Fri May 06, 2011 8:49 am    Post subject: Reply with quote
I'd go Koni.
PostPosted: Fri May 06, 2011 9:01 am    Post subject: Reply with quote
Ive been looking myself. I am thinking Koni front and KYB adjust rears.
PostPosted: Fri May 06, 2011 11:28 am    Post subject: Reply with quote
KYB's are great but still don't compare to Koni or Bilstein. I put Koni's in the back and they made the rear much more stable than the KYBs.
IROCDave
PostPosted: Fri May 06, 2011 6:12 pm    Post subject: Reply with quote
Just posted about this on ECM.
I have Koni adjustable shocks and struts on my car. When I put them on the car I also swapped out the stock springs to Iebachs so I cant really give you a clear opinion of the merits of Koni.
You are more than welcome to take my car out and form your own opinion or you can swap out the struts and shocks and see how they perform on your car. The caviat is that you will have to do the wrenching.
I would be intersted in the results. You never see a direct comparison between Koni and Bilsteen even though the price is similar.
Red Bird
1991 Pontiac Firebird
PostPosted: Sat May 07, 2011 12:13 am    Post subject: Reply with quote
I run Koni Yellow struts, and they are awesome. They stopped the nose diving under hard braking, settled my car down through slaloms in AutoX. You can adjust the stiffness, and they can be rebuilt/revalved to suit your application. Bilsteins cannot be rebuilt/revalved or are adjustable that im aware of. I would get Konis......
1991 Firebird L03 T-5
PostPosted: Mon Sep 05, 2011 8:00 pm    Post subject: Reply with quote
So I was under the car last weekend yanking the line lock off and flushing the brake system and realized the passenger side isn't leaking but the drivers side IS blown and has fluid all down the strut body. I'll be needing to get shocks/struts sooner rather than later and I was going to pull the trigger on KONIs when I saw AST now has an offering for our cars...
http://www.ast-suspension.com/index.asp
I could get these directly from stranoparts which would be nice as well.
Adjustable and rebuild-able just like the KONIs too. Thing that piques my interest with them is actually how highly recommended they are by Vorshlag Motorsports (the guys who did the LM7 e30 for the 2010 GRM challenge.) I'm about 90% sure I'm getting these...
IROCDave
PostPosted: Mon Sep 05, 2011 8:54 pm    Post subject: Reply with quote
Offer still stands and since my car is in limbo you can run them for awhile. I am working a 12 hour night shift starting Tuesday through Saturday morning. If your interested, Saturday morning would be a good time to pull them.
PostPosted: Mon Sep 05, 2011 9:02 pm    Post subject: Reply with quote
I don't see any offering for our cars on the AST website. Another thing to look into is the strut/shock height. It'd be nice to find some that fit our cars that have a shorter shaft.
PostPosted: Mon Sep 05, 2011 9:31 pm    Post subject: Reply with quote
I might take you up on this... I AM on vacation this week, but only from my paying job. I'm putting a new roof on the house finally. Very Happy
Actually, The ASTs say they have a 1" shorter body for lowered cars... Very Happy
http://www.stranoparts.com/partdetails.php?PartID=511&CategoryID=0&ModelID=10
and
http://www.vorshlag.com/product_info.php?cPath=212_213_219&products_id=364
PostPosted: Tue Sep 06, 2011 4:26 pm    Post subject: Reply with quote
I just put konis on the front, and kyb adjust on rear of mine. Still playing with them, but very nice as the front doesnt hop as much. Also got some of the front end plow removed. Still tinkering.
PostPosted: Tue Sep 06, 2011 4:33 pm    Post subject: Reply with quote
I just noticed that those AST's are adjustable for rebound only. Aren't Koni Yellows adjustable for both bound and rebound?
PostPosted: Tue Sep 06, 2011 5:57 pm    Post subject: Reply with quote
Koni Yellows are adjustable on rebound only (for our application).
The AST looks interesting, but is it really worth the extra cost?
I was planning on Koni Yellow all around, but AST may be better. I'm always open to choices! Smile Ian, I will get Koni and you get the AST and we'll do a side-by-side comparison. Wink
PostPosted: Wed Sep 07, 2011 7:57 pm    Post subject: Reply with quote
Laughing Side by side may not be that accurate since everything else about our cars is different!
PostPosted: Wed Sep 07, 2011 8:29 pm    Post subject: Reply with quote
True, should have been more clear on that one:
I meant just a shock-vs-shock comparison on apparent build quality, weight, length, etc.
Laughing
PostPosted: Wed Sep 07, 2011 9:00 pm    Post subject: Reply with quote
Ooooh, that works. I just ordered them. Very Happy
PostPosted: Thu Sep 08, 2011 5:17 am    Post subject: Reply with quote
Even with a blind comparison like that, height makes for a huge variable in how well the shock/strut can handle movement.
