86 bird headlights
PostPosted: Sat Aug 20, 2011 10:51 am    Post subject: 86 bird headlights Reply with quote
My headlights only pop up intermittently. the switch is cool, i checked it out. the motors sound fine, and pop right up when they work, and will work ten times in a row, then fail on the eleventh. What else coudl it be? i currently have a parts car, but don't even know what to grab off of it. any help is apriciated guys.
-tony
PostPosted: Sat Aug 20, 2011 12:39 pm    Post subject: Reply with quote
It probably is the nylon bushings in the motors, mine did the same progressively getting worse until I had to manually open them EVERY time. Got the Top down solutions $25 rebuild kit for the motors and they've worked perfect ever since.
PostPosted: Sat Aug 20, 2011 1:16 pm    Post subject: Reply with quote
I'm with stupid
Happened to mine finally late last year Tony. I just got the bushings from TDS, not the entire rebuild kit. There are like 3 nylon 'pucks' on each side. IIRC, one pack of 3 is $7 or something like that. I actually tried making my own but the material I used wasn't hard enough so I just paid Lon.
You can verify if this is it by taking the housing apart. I would bet that your former 'pucks' are a fine white powder instead of solid discs. Simple fix... get em coming.
PostPosted: Sat Aug 20, 2011 3:14 pm    Post subject: Reply with quote
86 popups don't work that way, the same way as later units. these have no bushing based clutch. the motor turns, they turn.
my motors do not even try to turn. this is why i don't think it's the clutches.
PostPosted: Sat Aug 20, 2011 7:15 pm    Post subject: Reply with quote
Ahhh ok. Must be another 87 and up deal.
Good luck.
PostPosted: Sat Aug 20, 2011 8:34 pm    Post subject: Reply with quote
Does the '86 use the headlight control module mounted on the firewall?
PostPosted: Sun Aug 21, 2011 1:39 am    Post subject: Reply with quote
... i dont know. i'll investigate.
PostPosted: Sun Aug 21, 2011 11:32 am    Post subject: Reply with quote
I got the same problem on my '86. The left side works perfectly but the right side pops only about 10% of the time. I barely have to nudge it to make it go up however which makes me believe the motor is still good. Confused
kurfbird
PostPosted: Sun Aug 21, 2011 12:30 pm    Post subject: headlight module Reply with quote
NO that is from 87-89 use one module
and 1990-2002 use a different module
kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
PostPosted: Tue Aug 23, 2011 6:32 am    Post subject: Reply with quote
no module.
kurfbird
PostPosted: Mon Aug 29, 2011 7:25 pm    Post subject: 86 bird Reply with quote
I ahve a 86 bird with all the relays for the headlights. LMK if youw ant the relays
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
