jchaussee Member
jchaussee Member
Posted: Thu Aug 25, 2011 8:31 pm Post subject: |
| The smallest one or the second smallest. I have a third line that you can see, and I just have a hose vented to the outside |
Posted: Thu Aug 25, 2011 8:51 pm Post subject: |
| The smallest line is the evap can. You can leave it open, but ideally you want to run some sort of catch on it (like an old fuel filter). |
jchaussee Member
Posted: Thu Aug 25, 2011 9:03 pm Post subject: |
| Cool. So I did something halfway right. When I got car, the mech fuel pump has a port with a 2 inch hose stuffed with a nut, so I assumed that was return so I hooked it up. The return line and evap line were just hooked to each other with some hose. Now I just need to find a way to route my lines better so they don't look like poo |
Posted: Fri Aug 26, 2011 8:51 am Post subject: |
| aaron_sK wrote: | | The smallest line is the evap can. You can leave it open, but ideally you want to run some sort of catch on it (like an old fuel filter). |
Filter isn't a catch can LOL. That evap line ends up being a vent for the tank, air goes in. Fuel doesn't come out. A little RC car filter is perfect. _________________ A redline a day keeps the carbon away! |
Posted: Fri Aug 26, 2011 5:39 pm Post subject: |
I know the filter isn't a catch can. It will keep crap out of the line, and it will keep whatever drops of gas might make it out with the vapor from hitting the ground. I used a plastic Wix carb filter on mine, ran it that way for years. |
