is this correct.
jchaussee
PostPosted: Thu Aug 25, 2011 4:34 pm    Post subject: is this correct. Reply with quote
So top line is Feed. Second going across front of engine is return for my mech fuel pump??
http://m1205.photobucket.com/albumview/albums/jchaussee/utf-8BSU1BRzAzMTQuanBn.jpg.html?newest=1&pbauth=1_uLEBonVPfaLdh1h3YMYz2eque2OYVf5Wyy%2BlETyNCb6GUMJortr84oQ3pRwTmHWwBSSVRpbi0lfOD6OCYrB4sfZtog868gZ%2FKVLgIbOay4LmjAAcLMBC4S82X8unbSAAU5WTwwl%2FY%2FNC7QETwYb3iJU%2FS9oiPzNX%2BZ0CKJFB9LM%3D
PostPosted: Thu Aug 25, 2011 8:23 pm    Post subject: Reply with quote
The big one is feed, small is return.
jchaussee
PostPosted: Thu Aug 25, 2011 8:31 pm    Post subject: Reply with quote
The smallest one or the second smallest. I have a third line that you can see, and I just have a hose vented to the outside
PostPosted: Thu Aug 25, 2011 8:51 pm    Post subject: Reply with quote
The smallest line is the evap can. You can leave it open, but ideally you want to run some sort of catch on it (like an old fuel filter).
jchaussee
PostPosted: Thu Aug 25, 2011 9:03 pm    Post subject: Reply with quote
Cool. So I did something halfway right. When I got car, the mech fuel pump has a port with a 2 inch hose stuffed with a nut, so I assumed that was return so I hooked it up. The return line and evap line were just hooked to each other with some hose. Now I just need to find a way to route my lines better so they don't look like poo
PostPosted: Fri Aug 26, 2011 8:51 am    Post subject: Reply with quote
Filter isn't a catch can LOL. That evap line ends up being a vent for the tank, air goes in. Fuel doesn't come out. A little RC car filter is perfect.
PostPosted: Fri Aug 26, 2011 5:39 pm    Post subject: Reply with quote
I know the filter isn't a catch can. Pokey pokey Rolling Eyes It will keep crap out of the line, and it will keep whatever drops of gas might make it out with the vapor from hitting the ground. I used a plastic Wix carb filter on mine, ran it that way for years.
