Posted: Thu Apr 07, 2011 5:22 pm Post subject: Press.. |
So I plan on ordering my del-a-lum bushings tomm even though they never messaged me back on a question I had.
I am wanting to get a press to push the bushings out/in, as well I plan to do my 1ton bushings and ball joints.
How big of ton rating do I need for this? Also, do they make tools to help press this stuff rather then making my own from pipes, sockets, etc.  _________________ 2008 GMC Z71
Posted: Thu Apr 07, 2011 8:05 pm Post subject: |
| Both times I had It done they used a puller and an impact gun. And for the sticky ones they used an air chisel. I will add, boxing the arm around the bushing helps out tremendously to get them out. |
Posted: Thu Apr 07, 2011 8:07 pm Post subject: |
Out with an air hammer, in with a large vise or press.
For ball joints, use the ball joint tool set or a press with the correct pressing pieces. _________________ A redline a day keeps the carbon away! |
Posted: Fri Apr 08, 2011 4:02 pm Post subject: |
Ive never seen them use an air-hammer around here. Just a press.
Ive personally done the bushings with a BFH, and I'm just getting to old for that now  |
Posted: Fri Apr 08, 2011 5:29 pm Post subject: |
Ew. These bushings have such a small metal sleeve I'd be worried about bending the crap out of em with a BFH.
Ball joints should fit TIGHT not so much BFH. _________________ A redline a day keeps the carbon away! |
