BluFbdy Member
Posted: Fri May 20, 2011 8:31 pm Post subject: Speed density memcal.... Need one bad |
so luke has brought it to my attention that I need a v8 tpi memcal because the ecm were using has a v6 and wont run the car if it ever goes into limp mode so I need a 7730 memcal and I need it fast, 305 ,350 doesnt matter just one lol did a seatch for an aujp and the price was thru the roof!
Were gonna burn a prom for it so as long as its for 8 cylinders im happy[/code] _________________ If you expect a kick to the balls and get a slap to the face its still a victory
BluFbdy Member
Posted: Fri May 20, 2011 9:25 pm Post subject: |
Wait can we use the v6 memcal? Or am I still on the hunt? _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Fri May 20, 2011 9:32 pm Post subject: |
| I think I misread your post. Your looking for the chip aside from the PROM, correct? Best chance might be at the yard, most of those cars still have the ECM. |
BluFbdy Member
Posted: Fri May 20, 2011 9:45 pm Post subject: |
I need the whole memcal _________________ If you expect a kick to the balls and get a slap to the face its still a victory
BluFbdy Member
Posted: Fri May 20, 2011 9:51 pm Post subject: |
Plus I couldnt find a Z around here to save my butt lol _________________ If you expect a kick to the balls and get a slap to the face its still a victory
91camaro_rs Member
Posted: Sat May 21, 2011 7:42 am Post subject: |
i have 2 V6 memcals and i was told that you cant use a v6 memcal and put a v8 350 prom on it because of the limp home mode is different,
so he is just looking for a 305 TPI speed density memcal, mine is AXXB or AXXF IIRC _________________
Posted: Sat May 21, 2011 11:16 am Post subject: |
I got a couple '730s sitting around but they are all V6s. I was gonna do the swap that Travis had done when he was autocrossing his V6 and never got around to it.  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
BluFbdy Member
Posted: Sat May 21, 2011 7:48 pm Post subject: |
??? meaning? is it possible to use a v6 memcal? ive seen "modded" ones but im kinda sketch on that _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Sat May 21, 2011 7:57 pm Post subject: |
| If you get the chance, make a trip to the Yank-a-Part in Poulsbo, from where you are, it's not too far. Go up Bond road toward Kingston, make a left at the light for Stottlemeyer Rd, then first left up a dirt drive, there's a sign at the drive. They have a decent selection of 3rd-gens and maybe one will have an intact ECM which you can pull the memcal. |
Posted: Sun May 22, 2011 8:13 am Post subject: |
A V6 memcal wont work in limp home mode very well. It's set for different sized injectors, 6 cyl spark, etc. _________________ A redline a day keeps the carbon away! |
BluFbdy Member
Posted: Sun May 22, 2011 10:43 am Post subject: |
Yeahh I figured.... Damn. The 305 will work tho right? _________________ If you expect a kick to the balls and get a slap to the face its still a victory
91camaro_rs Member
Posted: Sun May 22, 2011 10:07 pm Post subject: |
yeah it will, considering i have a 305 memcal, and i have used limp home mode lol _________________
BluFbdy Member
Posted: Sun May 22, 2011 10:21 pm Post subject: |
| 91camaro_rs wrote: | | yeah it will, considering i have a 305 memcal, and i have used limp home mode lol |
True _________________ If you expect a kick to the balls and get a slap to the face its still a victory
