Speed density memcal.... Need one bad
BluFbdy
PostPosted: Fri May 20, 2011 8:31 pm    Post subject: Speed density memcal.... Need one bad Reply with quote
so luke has brought it to my attention that I need a v8 tpi memcal because the ecm were using has a v6 and wont run the car if it ever goes into limp mode so I need a 7730 memcal and I need it fast, 305 ,350 doesnt matter just one lol did a seatch for an aujp and the price was thru the roof!
Were gonna burn a prom for it so as long as its for 8 cylinders im happy[/code]
PostPosted: Fri May 20, 2011 8:57 pm    Post subject: Reply with quote
I have an internet shortcut on my Tuner Pro CD from Moates which has a large selection of bins.
http://www.moates.net/fileman/index.php?dir=1%29%20Stock%20Binaries/DIY-EFI%20GMECM%20Binaries
Requires a user name and password which I'll PM
Open 1227730 727 01 A1 3E 46 51 55 6B 88 8D 96 D8, then open 8D, AUJP is in the 8D folder.
BluFbdy
PostPosted: Fri May 20, 2011 9:25 pm    Post subject: Reply with quote
Wait can we use the v6 memcal? Or am I still on the hunt?
PostPosted: Fri May 20, 2011 9:32 pm    Post subject: Reply with quote
I think I misread your post. Your looking for the chip aside from the PROM, correct? Best chance might be at the yard, most of those cars still have the ECM.
BluFbdy
PostPosted: Fri May 20, 2011 9:45 pm    Post subject: Reply with quote
I need the whole memcal
BluFbdy
PostPosted: Fri May 20, 2011 9:51 pm    Post subject: Reply with quote
Plus I couldnt find a Z around here to save my butt lol
91camaro_rs
PostPosted: Sat May 21, 2011 7:42 am    Post subject: Reply with quote
i have 2 V6 memcals and i was told that you cant use a v6 memcal and put a v8 350 prom on it because of the limp home mode is different,
so he is just looking for a 305 TPI speed density memcal, mine is AXXB or AXXF IIRC
PostPosted: Sat May 21, 2011 11:16 am    Post subject: Reply with quote
I got a couple '730s sitting around but they are all V6s. I was gonna do the swap that Travis had done when he was autocrossing his V6 and never got around to it. Sad
BluFbdy
PostPosted: Sat May 21, 2011 7:48 pm    Post subject: Reply with quote
??? meaning? is it possible to use a v6 memcal? ive seen "modded" ones but im kinda sketch on that
PostPosted: Sat May 21, 2011 7:57 pm    Post subject: Reply with quote
If you get the chance, make a trip to the Yank-a-Part in Poulsbo, from where you are, it's not too far. Go up Bond road toward Kingston, make a left at the light for Stottlemeyer Rd, then first left up a dirt drive, there's a sign at the drive. They have a decent selection of 3rd-gens and maybe one will have an intact ECM which you can pull the memcal.
PostPosted: Sun May 22, 2011 8:13 am    Post subject: Reply with quote
A V6 memcal wont work in limp home mode very well. It's set for different sized injectors, 6 cyl spark, etc.
BluFbdy
PostPosted: Sun May 22, 2011 10:43 am    Post subject: Reply with quote
Yeahh I figured.... Damn. The 305 will work tho right?
91camaro_rs
PostPosted: Sun May 22, 2011 10:07 pm    Post subject: Reply with quote
yeah it will, considering i have a 305 memcal, and i have used limp home mode lol
BluFbdy
PostPosted: Sun May 22, 2011 10:21 pm    Post subject: Reply with quote
True
