Torque Arm
nonsensekid20
PostPosted: Tue Feb 01, 2011 8:56 pm    Post subject: Torque Arm Reply with quote
So I was reading through the chiltons manual and it said the coil springs must be removed before the torque arm. If the torque arm is removed first, vehicle damage will result.
What type of damage is it talkin about?
PostPosted: Tue Feb 01, 2011 9:00 pm    Post subject: Reply with quote
Rear end can rotate without the torque arm attached, which can damage the shocks, panhard bar, u-joint, or possibly shoot springs out at a high rate of speed.
That's the first stuff that comes to mind.
PostPosted: Tue Feb 01, 2011 9:03 pm    Post subject: Reply with quote
The more important question is why you want to remove the torque arm in the first place? Don't tell me you decided to jack under that and bent it too!
nonsensekid20
PostPosted: Tue Feb 01, 2011 9:06 pm    Post subject: Reply with quote
Lol. We just wanted to know what type of damage it could do.
Anytime we drive the car we're swervin like we're drunk. hahah. Drinkin and singin Probly just needs the front end alignment.
PostPosted: Tue Feb 01, 2011 9:09 pm    Post subject: Reply with quote
In that case, Gabe is correct. Without the torque arm the axle is not rotationally secured.
nonsensekid20
PostPosted: Tue Feb 01, 2011 9:11 pm    Post subject: Reply with quote
Now I don't think there is, but is there a way to put the torque arm on wrong?
PostPosted: Tue Feb 01, 2011 10:07 pm    Post subject: Reply with quote
It only goes on one way but the holes are big enough that there is some slop at the mount. I always leave my torque arm bolts loose on the axle until it's all put together.
I feel it's necessary to mention, there are two types of torque arms that require different torque arm mounts.
PostPosted: Thu Feb 03, 2011 9:32 pm    Post subject: Reply with quote
I knew there were two different torque arm mounts but I did not know there were two different torque arms. Care to expand on this?
PostPosted: Thu Feb 03, 2011 9:35 pm    Post subject: Reply with quote
The "W" is either towards the driver or passenger side. I can't remember the years associated with it. Also they made a torque arm that was solid and one with holes punched out of it. My 89 stuff was all solid. Dang I wish I could remember.
PostPosted: Thu Feb 03, 2011 9:38 pm    Post subject: Reply with quote
82 and 83 were different. IIRC it was due to the shorter transmissions. The 'W' on the bushing end goes the other way on the oddball ones.
