nonsensekid20 Member
Posted: Tue Feb 01, 2011 8:56 pm Post subject: Torque Arm |
So I was reading through the chiltons manual and it said the coil springs must be removed before the torque arm. If the torque arm is removed first, vehicle damage will result.
What type of damage is it talkin about? |
Posted: Tue Feb 01, 2011 9:00 pm Post subject: |
Rear end can rotate without the torque arm attached, which can damage the shocks, panhard bar, u-joint, or possibly shoot springs out at a high rate of speed.
That's the first stuff that comes to mind. _________________ 84 Camaro Z28 - LS1/T56
Posted: Tue Feb 01, 2011 9:03 pm Post subject: |
| The more important question is why you want to remove the torque arm in the first place? Don't tell me you decided to jack under that and bent it too! |
Posted: Tue Feb 01, 2011 9:06 pm Post subject: |
Lol. We just wanted to know what type of damage it could do.
Anytime we drive the car we're swervin like we're drunk. hahah. Probly just needs the front end alignment.
Last edited by nonsensekid20 on Tue Feb 01, 2011 9:10 pm; edited 1 time in total |
Posted: Tue Feb 01, 2011 9:09 pm Post subject: |
| nonsensekid20 wrote: | | We just wanted to know what type of damage it could do. |
In that case, Gabe is correct. Without the torque arm the axle is not rotationally secured. |
Posted: Tue Feb 01, 2011 9:11 pm Post subject: |
| Now I don't think there is, but is there a way to put the torque arm on wrong? |
Posted: Tue Feb 01, 2011 10:07 pm Post subject: |
It only goes on one way but the holes are big enough that there is some slop at the mount. I always leave my torque arm bolts loose on the axle until it's all put together.
I feel it's necessary to mention, there are two types of torque arms that require different torque arm mounts. _________________ E30
Posted: Thu Feb 03, 2011 9:32 pm Post subject: |
I knew there were two different torque arm mounts but I did not know there were two different torque arms. Care to expand on this? _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Thu Feb 03, 2011 9:35 pm Post subject: |
| The "W" is either towards the driver or passenger side. I can't remember the years associated with it. Also they made a torque arm that was solid and one with holes punched out of it. My 89 stuff was all solid. Dang I wish I could remember. |
Posted: Thu Feb 03, 2011 9:38 pm Post subject: |
| 82 and 83 were different. IIRC it was due to the shorter transmissions. The 'W' on the bushing end goes the other way on the oddball ones. |
