91camaro_rs Member
Posted: Tue Feb 01, 2011 12:18 pm Post subject: fan being retarded |
ok so my fan was on its own little harness i made and it was on a manual switch with an automatic switch for when it hit 200* and so i hooked the fan back into the wiring harness of the car so its setup like stock now, using the stock fan relay, i used tuner pro and set my fan enable at 195 and disable at 180
but the fan turns on when the ignition is on.... why is that
also my aldl wont connect anymore idk whats up with that _________________
91camaro_rs Member
Posted: Tue Feb 01, 2011 12:29 pm Post subject: |
engine code 51 prom error came up, which means chip didnt get burned right, im gonna try it again _________________
popballz Member
Posted: Tue Feb 01, 2011 12:45 pm Post subject: Re: fan being retarded |
| 91camaro_rs wrote: |
I don't know your fan setup but the relay turns on when one of the 3 or so wires are grounded. my "temp switch" turns my fan on, all it does is ground the wire when it gets hot enough
so make sure your wires are not grounded where they shouldn't be. I hope that made sense.. _________________ -Donald
91camaro_rs Member
Posted: Tue Feb 01, 2011 12:49 pm Post subject: |
re burned the chip and all is good  _________________
Posted: Tue Feb 01, 2011 3:24 pm Post subject: |
My fan came on with improperly burned chips.
And or you've got it wired incorrectly. _________________ A redline a day keeps the carbon away! |
Posted: Tue Feb 01, 2011 7:26 pm Post subject: |
Yeah, code 51 kicks the fan.  |
91camaro_rs Member
Posted: Tue Feb 01, 2011 11:30 pm Post subject: |
when i did the fan wiring i changed where the ground goes to a better spot and i used a new nut and bolt for my halo/headlight ground... i guess i need to sand the paint off where the bolt goes in cause its not making a good connection, my high beams are on super dim so they are orange, and my right turn indicator on the cluster stays on....haha ill fix that ground tomorrow, i wanna start dealing with highway fuel mode next _________________
BluFbdy Member
Posted: Wed Feb 02, 2011 1:26 am Post subject: |
oh yeah we should have looked at that saturday lol between the gas and coil i think we got a bit distracted though lol good to hear you got it working though, did you ever figure out the coil issue?? _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Wed Feb 02, 2011 7:31 am Post subject: |
| Shake proof washers... you know the ones with teeth, are awesome for grounds. They'll dig through the paint without having to remove it. |
91camaro_rs Member
Posted: Wed Feb 02, 2011 8:29 am Post subject: |
sweet ill get one of those on there,
and no i havent figured out the coil issue yet, for all i know the connector is halfway off but it starts everytime... _________________
