v6 transmisson
corey davidson
1986 Chevrolet Camaro
PostPosted: Mon Oct 11, 2010 3:53 pm    Post subject: v6 transmisson Reply with quote
So I got a 86 blazer now. The transmission is shot and i need a new one thought id check to see if any one had one. I don't care if its a manual or auto i just need one for cheap.
real men are covered in oil and grease
PostPosted: Mon Oct 11, 2010 3:56 pm    Post subject: Reply with quote
LOL You're prepared to swap one for the other? It's just like an F-Body until you get to 1994. Easy, but not cheap.
corey davidson
PostPosted: Mon Oct 11, 2010 4:00 pm    Post subject: Reply with quote
lol its an 86 so score lol its a good truck besides its the 2.8 and the transmission is crap
corey davidson
PostPosted: Mon Oct 11, 2010 4:04 pm    Post subject: Reply with quote
i only paid 650 for the truck so if i can get a 700r4 for now ill deal till i get a 350 build for it.
PostPosted: Mon Oct 11, 2010 5:04 pm    Post subject: Reply with quote
Get the Jagsthatrun S-10V8 book if you're going that route. It will save you.
Of course I fail to see it going that far based on your do factor of cars Laughing Wink
I had a 2.8L and 4.3L 4x4 jimmys of that era. I used a Camaro 2.8L engine in and put the 2.8L carbed stuff from the jimmy back on top. The 2.8L with a 5speed out MPG, Out Drove, Out ran the 4.3L with a Built 700r4. I ended up trading the 4.3 guy in even after I put vortec heads/intake on it... because it was still so damn gutless.
corey davidson
PostPosted: Mon Oct 11, 2010 5:29 pm    Post subject: Reply with quote
Laughing not funny Laughing If I can find a t5 for it i would be a very happy camper. Than I'd build the 2.8. its a remanded so thats a plus the only problem is the transmission oh an no speedometer.
PostPosted: Mon Oct 11, 2010 7:59 pm    Post subject: Reply with quote
Just get another JY 700 for a few bucks and throw it in. Drive it, blow it up, rinse and repeat. Bearings in the 2.8 are gonna go sometime anyhow. No sense throwing good money into it. *two cents*
BTW, the 60* bell five speed set up for the t-case is kind of a rare unit. Most 4x4's got the auto or the 90* motor.
91camaro_rs
PostPosted: Mon Oct 11, 2010 9:31 pm    Post subject: Reply with quote
donald has a T-5 for sale, i think he wants 100 for it
corey davidson
PostPosted: Mon Oct 11, 2010 9:33 pm    Post subject: Reply with quote
idk I'v priced the 700 they are like 400$. But, I found a t5 for 250 I'm crossing my fingers that it is good. The 2.8 will be gone before the bearings go i hope. Thanks for your 2 cents Aaron ill take any two cents on this subject i like the truck its a good truck.
corey davidson
PostPosted: Mon Oct 11, 2010 9:34 pm    Post subject: Reply with quote
v-6? does it need rebuild or do you know?
PostPosted: Mon Oct 11, 2010 10:17 pm    Post subject: Reply with quote
Donald's T5 is from a V6. You will need to find some business like this to mate it to the t-case...
corey davidson
PostPosted: Mon Oct 11, 2010 10:35 pm    Post subject: Reply with quote
hmm I might have to get a hold of him after I check on the other 2 leads I got
kurfbird
PostPosted: Tue Oct 12, 2010 5:05 am    Post subject: 700r4 Reply with quote
I have a 700r4 from a 86 bird 100.00 not sure if it wuill work for your applicaton
kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
corey davidson
PostPosted: Tue Oct 12, 2010 10:46 am    Post subject: Reply with quote
what engine did it come off of
91camaro_rs
PostPosted: Tue Oct 12, 2010 11:24 am    Post subject: Reply with quote
donalds tranny came from me, it was off a 2.8 camaro, and the car was parted and the guy i got the tranny from said it worked when it was in the car
corey davidson
PostPosted: Tue Oct 12, 2010 11:40 am    Post subject: Reply with quote
ok
PostPosted: Tue Oct 12, 2010 3:43 pm    Post subject: Reply with quote
If your blazer is 4x4 to make a non 4x4 v6t5 work you'll need to find a 4x4 main shaft and top plate shaft. Completely disassemble the trans to install it.
$400 for a bolt and go or:
$40atf
OR
$250 for a used 4x4 t5
$25 pedals
$100 clutch
$100 hydraulics
$15 crossmember
$25 used flywheel
$25 surface flywheel
$10 pilot bushing
$8 brake fluid
$75 bellhousing/clutch fork
Days of work
IIRC the 4x4t5 is a different length than the 4x4 700r4. That means driveline mods if that's the case.
Hope the trans works.
How is going standard cheaper/easier?
PostPosted: Tue Oct 12, 2010 4:08 pm    Post subject: Reply with quote
That's pretty much all I know, I thought I would use it but didn't, but I am way up here in Tacoma.
-Donald
PostPosted: Tue Oct 12, 2010 5:48 pm    Post subject: Reply with quote
Why do I see alot of trans work in my future reading this..... Rolling Eyes I'm going with Aaron's idea on this one and I'm trying to get dippy to understand how much work it is to swap auto to manual....
PostPosted: Tue Oct 12, 2010 6:43 pm    Post subject: Reply with quote
GREG DAVIDSON wrote:
dippy
Laughing so hard it hurts
