corey davidson Member
1986 Chevrolet Camaro
Posted: Mon Oct 11, 2010 3:53 pm Post subject: v6 transmisson |
So I got a 86 blazer now. The transmission is shot and i need a new one thought id check to see if any one had one. I don't care if its a manual or auto i just need one for cheap. _________________ real men are covered in oil and grease |
Posted: Mon Oct 11, 2010 3:56 pm Post subject: |
LOL You're prepared to swap one for the other? It's just like an F-Body until you get to 1994. Easy, but not cheap. _________________ A redline a day keeps the carbon away! |
Posted: Mon Oct 11, 2010 4:00 pm Post subject: |
lol its an 86 so score lol its a good truck besides its the 2.8 and the transmission is crap _________________ real men are covered in oil and grease |
Posted: Mon Oct 11, 2010 4:04 pm Post subject: |
i only paid 650 for the truck so if i can get a 700r4 for now ill deal till i get a 350 build for it. _________________ real men are covered in oil and grease |
Posted: Mon Oct 11, 2010 5:04 pm Post subject: |
Get the Jagsthatrun S-10V8 book if you're going that route. It will save you.
Of course I fail to see it going that far based on your do factor of cars
I had a 2.8L and 4.3L 4x4 jimmys of that era. I used a Camaro 2.8L engine in and put the 2.8L carbed stuff from the jimmy back on top. The 2.8L with a 5speed out MPG, Out Drove, Out ran the 4.3L with a Built 700r4. I ended up trading the 4.3 guy in even after I put vortec heads/intake on it... because it was still so damn gutless. _________________ A redline a day keeps the carbon away! |
Posted: Mon Oct 11, 2010 5:29 pm Post subject: |
not funny If I can find a t5 for it i would be a very happy camper. Than I'd build the 2.8. its a remanded so thats a plus the only problem is the transmission oh an no speedometer. _________________ real men are covered in oil and grease |
Posted: Mon Oct 11, 2010 7:59 pm Post subject: |
Just get another JY 700 for a few bucks and throw it in. Drive it, blow it up, rinse and repeat. Bearings in the 2.8 are gonna go sometime anyhow. No sense throwing good money into it. *two cents*
BTW, the 60* bell five speed set up for the t-case is kind of a rare unit. Most 4x4's got the auto or the 90* motor. |
91camaro_rs Member
Posted: Mon Oct 11, 2010 9:31 pm Post subject: |
donald has a T-5 for sale, i think he wants 100 for it _________________
Posted: Mon Oct 11, 2010 9:33 pm Post subject: |
idk I'v priced the 700 they are like 400$. But, I found a t5 for 250 I'm crossing my fingers that it is good. The 2.8 will be gone before the bearings go i hope. Thanks for your 2 cents Aaron ill take any two cents on this subject i like the truck its a good truck. _________________ real men are covered in oil and grease |
Posted: Mon Oct 11, 2010 9:34 pm Post subject: |
| 91camaro_rs wrote: | | donald has a T-5 for sale, i think he wants 100 for it |
v-6? does it need rebuild or do you know? _________________ real men are covered in oil and grease |
Posted: Mon Oct 11, 2010 10:17 pm Post subject: |
| Donald's T5 is from a V6. You will need to find some business like this to mate it to the t-case... |
Posted: Mon Oct 11, 2010 10:35 pm Post subject: |
hmm I might have to get a hold of him after I check on the other 2 leads I got _________________ real men are covered in oil and grease |
kurfbird Member
Posted: Tue Oct 12, 2010 5:05 am Post subject: 700r4 |
I have a 700r4 from a 86 bird 100.00 not sure if it wuill work for your applicaton _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
Posted: Tue Oct 12, 2010 10:46 am Post subject: |
what engine did it come off of
91camaro_rs Member
Posted: Tue Oct 12, 2010 11:24 am Post subject: |
donalds tranny came from me, it was off a 2.8 camaro, and the car was parted and the guy i got the tranny from said it worked when it was in the car _________________
Posted: Tue Oct 12, 2010 11:40 am Post subject: |
ok _________________ real men are covered in oil and grease |
Posted: Tue Oct 12, 2010 3:43 pm Post subject: |
If your blazer is 4x4 to make a non 4x4 v6t5 work you'll need to find a 4x4 main shaft and top plate shaft. Completely disassemble the trans to install it.
$400 for a bolt and go or:
$40atf
OR
$250 for a used 4x4 t5
$25 pedals
$100 clutch
$100 hydraulics
$15 crossmember
$25 used flywheel
$25 surface flywheel
$10 pilot bushing
$8 brake fluid
$75 bellhousing/clutch fork
Days of work
IIRC the 4x4t5 is a different length than the 4x4 700r4. That means driveline mods if that's the case.
Hope the trans works.
How is going standard cheaper/easier? _________________ A redline a day keeps the carbon away! |
popballz Member
Posted: Tue Oct 12, 2010 4:08 pm Post subject: |
| 91camaro_rs wrote: | | donalds tranny came from me, it was off a 2.8 camaro, and the car was parted and the guy i got the tranny from said it worked when it was in the car |
That's pretty much all I know, I thought I would use it but didn't, but I am way up here in Tacoma. _________________ -Donald
GREG DAVIDSON Member
Posted: Tue Oct 12, 2010 5:48 pm Post subject: |
Why do I see alot of trans work in my future reading this..... I'm going with Aaron's idea on this one and I'm trying to get dippy to understand how much work it is to swap auto to manual.... |
Posted: Tue Oct 12, 2010 6:43 pm Post subject: |
| GREG DAVIDSON wrote: | | dippy |
