cast steel l98 exhaust manifolds
PostPosted: Fri Oct 01, 2004 8:27 am    Post subject: cast steel l98 exhaust manifolds Reply with quote
Wanting to try a turbo setup with the stock cast log. Anyone have any or know where to get them? Seen them at a yard nearby? Finders fee! Very Happy Any help would be appreciated...
PostPosted: Fri Oct 01, 2004 9:24 am    Post subject: Reply with quote
If there the same as the LB9 manifolds I will have a set in a couple weeks when I get back from hunting. They can be yours for the price of shipping them.
Jess
Administrator
PostPosted: Fri Oct 01, 2004 10:16 am    Post subject: Reply with quote
I also have a set of LB9 manifolds if they'll work for you and you want to get a set quicker. Or take both or ours and try and port a set Wink
PostPosted: Fri Oct 01, 2004 9:33 pm    Post subject: Reply with quote
I'm not sure if they're the same; I've been trying to figure that out at both 3GO and TGO--If they are I've got three sets already. Very Happy Thanks for the quick responses guys. Do any of you know how to tell the diff between cast steel and iron?
JohnnyIROC-Z
1995 Pontiac Formula
PostPosted: Sat Oct 02, 2004 4:26 am    Post subject: Reply with quote
I'd imagine weight would be one factor. I'm also thinking you could try to weld something to it... umm you could shave metal off some steel and iron and take them and have it analyzed. Ya that's the ticket.... Other than that.. I'm sure the cast steel would be lighter than cast iron since steel is an alloy of iron and i believe aluminum
