Posted: Fri Oct 01, 2004 8:27 am Post subject: cast steel l98 exhaust manifolds |
Wanting to try a turbo setup with the stock cast log. Anyone have any or know where to get them? Seen them at a yard nearby? Finders fee! Any help would be appreciated... _________________
Posted: Fri Oct 01, 2004 9:24 am Post subject: |
| If there the same as the LB9 manifolds I will have a set in a couple weeks when I get back from hunting. They can be yours for the price of shipping them. |
Jess Administrator
Joined: 24 Nov 2003 Posts: 429 Location: Mount Vernon, WA
Posted: Fri Oct 01, 2004 10:16 am Post subject: |
I also have a set of LB9 manifolds if they'll work for you and you want to get a set quicker. Or take both or ours and try and port a set  |
Posted: Fri Oct 01, 2004 9:33 pm Post subject: |
I'm not sure if they're the same; I've been trying to figure that out at both 3GO and TGO--If they are I've got three sets already. Thanks for the quick responses guys. Do any of you know how to tell the diff between cast steel and iron? |
JohnnyIROC-Z Member
Joined: 14 Jan 2004 Posts: 204 Location: Washougal, WA
1995 Pontiac Formula
Posted: Sat Oct 02, 2004 4:26 am Post subject: |
| I'd imagine weight would be one factor. I'm also thinking you could try to weld something to it... umm you could shave metal off some steel and iron and take them and have it analyzed. Ya that's the ticket.... Other than that.. I'm sure the cast steel would be lighter than cast iron since steel is an alloy of iron and i believe aluminum |
