Dummy lights -> Gauges
d00012
PostPosted: Thu Mar 04, 2010 12:45 pm    Post subject: Dummy lights -> Gauges Reply with quote
What temp sensor am I replacing? The Coolant or the engine temp?
PostPosted: Thu Mar 04, 2010 1:06 pm    Post subject: Reply with quote
probably Engine Temp.
d00012
PostPosted: Thu Mar 04, 2010 1:12 pm    Post subject: Reply with quote
Where is that one located? Is that the one on the front of the driver side head?
And the oil pressure one is above the filter housing? Correct?
PostPosted: Thu Mar 04, 2010 1:14 pm    Post subject: Reply with quote
I couldn't tell you for sure, but my guess would be yes. Hopefully someone with a bit more experience with the 2.8 MPFI cars will chime in here.
d00012
PostPosted: Thu Mar 04, 2010 1:22 pm    Post subject: Reply with quote
Looking at the oil pressure sensors for the gauge, and the threading is different than the light ones, how come? Why do they have to make the pictures so deceiving?
I thought this cluster swap was supposed to be simple...
I think I'm just over thinking this. Too much going on.
Edit: Confirmed the location of temp sensor. Just don't know how the oil pressure one is going to work, judging from the photos...the threads are different bleh. Light is 1/4 and Gauge is 1/8 according to Summit Bashy Bashy
d00012
PostPosted: Thu Mar 04, 2010 1:54 pm    Post subject: Reply with quote
Nevermind...I figured it out...I hate stress, screws up my thought process and I can't focus on the things I love.
PostPosted: Thu Mar 04, 2010 6:55 pm    Post subject: Reply with quote
Adapters, man! Any local hardware store can set you up for pocket change.
d00012
PostPosted: Thu Mar 04, 2010 9:15 pm    Post subject: Reply with quote
The actual oil gauge switch is above the fuel pump switch...it's the 1/8"
Just overstressed from personal life, I was freaking out about things I shouldn't have. Laughing
d00012
PostPosted: Sat Mar 06, 2010 10:05 am    Post subject: Reply with quote
Anyone know if it would be ok if I installed the new cluster WITHOUT the right sensors? I know they aren't computer controlled, but would it damage the gauges or mess up the circuit?
Would it be safe to disconnect them until I get new ones?
d00012
PostPosted: Sun Mar 07, 2010 3:10 pm    Post subject: Reply with quote
Bump...
PostPosted: Sun Mar 07, 2010 3:32 pm    Post subject: Reply with quote
Swapped from idiot lights to idiot dials in my S10. Just left the wires unhooked and taped off till I got the sending units installed.
d00012
PostPosted: Sun Mar 07, 2010 8:43 pm    Post subject: Reply with quote
Ok cool. I'm swapping it in the morning then. Very Happy
Yay! A 115 mph speedo and a tach! Finally...
Thanks Al!
