Posted: Sun Feb 14, 2010 2:58 pm Post subject: Garage axle storage.... |
You guys have any clever ways you've stored your spare axles? I have two in my garage at the moment that I'd like to keep around. Unfortunately they take up a bit of space. Any suggestions? _________________ E30
Posted: Sun Feb 14, 2010 3:07 pm Post subject: |
| You talking about axle shafts, or the entire rear axle assembly? |
Posted: Sun Feb 14, 2010 4:26 pm Post subject: |
| The entire housing. I have a 10-bolt and a 9-bolt that I want to keep. |
Posted: Sun Feb 14, 2010 6:46 pm Post subject: |
Built a couple "X" stands out of 2x4 lumber. Support it by the axle tubes and place one axle over the other. Box in the X for strength.
_
X |
Posted: Mon Feb 15, 2010 6:29 am Post subject: |
| blue89 wrote: | | The entire housing. I have a 10-bolt and a 9-bolt that I want to keep. |
I had two 8" Ford rears I stored at one point. One was my dad's, one was mine.
Drain all the fluids out, stand them vertically with rims/tires attached. corners of the garage are good. I had to spend a day re-arranging things to make it work.
just a thought. _________________
Posted: Mon Feb 15, 2010 6:23 pm Post subject: |
| I was thinking of something like x-frames or something racky. I moved them over to another spot in my garage and put them up on blocks. I'm thinking of putting blocks on top of them and then making a short bench top on top of that. Then it won't be totally wasted space cause I can use the space for work or storing. |
Posted: Wed Feb 17, 2010 9:50 am Post subject: |
looks like the brakes on those things are the biggest problem of taking up space. I'll let you store the brake calipers and rotors at my place and it will save you tons of space.
Posted: Wed Feb 17, 2010 10:00 am Post subject: |
| 83Z28BlackBetty wrote: | I'll let you store the brake calipers and rotors on my car and it will save you tons of space.
Fixed  |
popballz Member
Posted: Wed Feb 17, 2010 2:14 pm Post subject: |
| 91RSVert wrote: | | 83Z28BlackBetty wrote: | I'll let you store the brake calipers and rotors on my car and it will save you tons of space.
Fixed  |
psh, you can store the whole rear end on my car  _________________ -Donald
Posted: Wed Feb 17, 2010 6:58 pm Post subject: |
| Lol, just got the rest of the stuff for the 12" LSx front brake swap to match my LT1 11.5" rear setup. I have a 9 bolt brake setup I could pawn off if someone wanted it. |
Boostd1 12sec Club
Joined: 28 Oct 2008 Posts: 437 Location: Thornton, Colorado
Posted: Wed Feb 17, 2010 11:20 pm Post subject: |
I found out a good way to store a read end. What you do is...
Oh wait  _________________ 1998 Grand Prix GT | 12.91 @ 103 - Sold/Retired
2008 Saturn Astra XR | Sold
2007 Infiniti G35x | Current DD |
Posted: Thu Feb 18, 2010 6:02 pm Post subject: |
haha. boosted1 = rwd fail
Boostd1 12sec Club
Posted: Thu Feb 18, 2010 6:31 pm Post subject: |
| blue89 wrote: | haha. boosted1 = rwd fail
I still make it happen. It is fun punching it from highway rolls and spinning tires though. _________________ 1998 Grand Prix GT | 12.91 @ 103 - Sold/Retired
Posted: Thu Feb 18, 2010 8:09 pm Post subject: |
Nice! |
Posted: Fri Feb 19, 2010 11:54 pm Post subject: |
| Here's what I ended up doing. Got some 2x4's laid on top. Then cut a piece of plywood over the top of it to make a bench out of it. With the axles overlapping the input shafts you'd never know there were two in there. The plywood sits on the 2x4's, the center housing, and the disk brakes well enough that I can sit on it without it moving. |
Posted: Sat Feb 20, 2010 8:10 am Post subject: |
| Quote: | | to make a bench out of it |
How tall are you??
Posted: Sat Feb 20, 2010 10:09 am Post subject: |
| rjmcgee wrote: | | Quote: | | to make a bench out of it |
How tall are you??
Bench to sit on would be about right. He's slightly taller than I am  _________________ 92 Camaro
Posted: Sat Feb 20, 2010 11:20 am Post subject: |
| Lol, ya, a bench to put stuff on, not to work off of. I'm 6'3" so it's about good to sit on but that's about it. I'm just happy it isn't wasted space and I have more room for cars now. |
Posted: Sat Feb 20, 2010 11:57 am Post subject: |
You're made a bench out of car parts and wood stacked in a pile? Redneck.
Just build a proper bench with enough space to fit the axles between the legs. It's a couple 2x4's and some nails. |
Posted: Sat Feb 20, 2010 2:27 pm Post subject: |
| QwkTrip wrote: |
And thats not either? |
