Garage axle storage....
PostPosted: Sun Feb 14, 2010 2:58 pm    Post subject: Garage axle storage.... Reply with quote
You guys have any clever ways you've stored your spare axles? I have two in my garage at the moment that I'd like to keep around. Unfortunately they take up a bit of space. Any suggestions?
PostPosted: Sun Feb 14, 2010 3:07 pm    Post subject: Reply with quote
You talking about axle shafts, or the entire rear axle assembly?
PostPosted: Sun Feb 14, 2010 4:26 pm    Post subject: Reply with quote
The entire housing. I have a 10-bolt and a 9-bolt that I want to keep.
PostPosted: Sun Feb 14, 2010 6:46 pm    Post subject: Reply with quote
Built a couple "X" stands out of 2x4 lumber. Support it by the axle tubes and place one axle over the other. Box in the X for strength.
_
X
PostPosted: Mon Feb 15, 2010 6:29 am    Post subject: Reply with quote
I had two 8" Ford rears I stored at one point. One was my dad's, one was mine.
Drain all the fluids out, stand them vertically with rims/tires attached. corners of the garage are good. I had to spend a day re-arranging things to make it work.
just a thought.
PostPosted: Mon Feb 15, 2010 6:23 pm    Post subject: Reply with quote
I was thinking of something like x-frames or something racky. I moved them over to another spot in my garage and put them up on blocks. I'm thinking of putting blocks on top of them and then making a short bench top on top of that. Then it won't be totally wasted space cause I can use the space for work or storing.
PostPosted: Wed Feb 17, 2010 9:50 am    Post subject: Reply with quote
looks like the brakes on those things are the biggest problem of taking up space. I'll let you store the brake calipers and rotors at my place and it will save you tons of space.
PostPosted: Wed Feb 17, 2010 10:00 am    Post subject: Reply with quote
83Z28BlackBetty wrote:
I'll let you store the brake calipers and rotors on my car and it will save you tons of space.
Fixed Laughing
PostPosted: Wed Feb 17, 2010 2:14 pm    Post subject: Reply with quote
Fixed Laughing
psh, you can store the whole rear end on my car Wink
-Donald
PostPosted: Wed Feb 17, 2010 6:58 pm    Post subject: Reply with quote
Lol, just got the rest of the stuff for the 12" LSx front brake swap to match my LT1 11.5" rear setup. I have a 9 bolt brake setup I could pawn off if someone wanted it.
Boostd1
PostPosted: Wed Feb 17, 2010 11:20 pm    Post subject: Reply with quote
I found out a good way to store a read end. What you do is...
Oh wait Evil or Very Mad
2008 Saturn Astra XR | Sold
PostPosted: Thu Feb 18, 2010 6:02 pm    Post subject: Reply with quote
haha. boosted1 = rwd fail
Razz
Boostd1
PostPosted: Thu Feb 18, 2010 6:31 pm    Post subject: Reply with quote
Razz
I still make it happen. It is fun punching it from highway rolls and spinning tires though.
PostPosted: Thu Feb 18, 2010 8:09 pm    Post subject: Reply with quote
Laughing Nice!
PostPosted: Fri Feb 19, 2010 11:54 pm    Post subject: Reply with quote
Here's what I ended up doing. Got some 2x4's laid on top. Then cut a piece of plywood over the top of it to make a bench out of it. With the axles overlapping the input shafts you'd never know there were two in there. The plywood sits on the 2x4's, the center housing, and the disk brakes well enough that I can sit on it without it moving.
PostPosted: Sat Feb 20, 2010 8:10 am    Post subject: Reply with quote
How tall are you??
Laughing
PostPosted: Sat Feb 20, 2010 10:09 am    Post subject: Reply with quote
How tall are you??
Laughing
Bench to sit on would be about right. He's slightly taller than I am Cool
PostPosted: Sat Feb 20, 2010 11:20 am    Post subject: Reply with quote
Lol, ya, a bench to put stuff on, not to work off of. I'm 6'3" so it's about good to sit on but that's about it. I'm just happy it isn't wasted space and I have more room for cars now.
PostPosted: Sat Feb 20, 2010 11:57 am    Post subject: Reply with quote
You're made a bench out of car parts and wood stacked in a pile? Redneck. Laughing
Just build a proper bench with enough space to fit the axles between the legs. It's a couple 2x4's and some nails.
PostPosted: Sat Feb 20, 2010 2:27 pm    Post subject: Reply with quote
And thats not either?
