Jet Chips
91camaro_rs
PostPosted: Sat Jan 23, 2010 10:55 pm    Post subject: Jet Chips Reply with quote
i have a stage 1 jet chip in my car, and i honestly dont recall why i put it in there and its been so long that i dont remember it making a difference, probably cause it didnt. anyone have any experience or knowledge with these and know if its even worth keeping it in the car
izcain
9sec Club
PostPosted: Sat Jan 23, 2010 11:14 pm    Post subject: Reply with quote
Most of the time when you look at those chips and you compare fuel tables with stock ones they look almost identical. Not worth the money!
9.17 @ 148
PostPosted: Sat Jan 23, 2010 11:37 pm    Post subject: Reply with quote
I'm with stupid
Might net you a couple degrees of timing, and maybe turn your fans on sooner. That's about it. As long as there's no detonation, it should be fine to leave it in there.
You've got a V6 anyway. What kind of gains were you expecting to see? Laughing
PostPosted: Sun Jan 24, 2010 8:28 am    Post subject: Reply with quote
Poor little six. I have a hypertech chip somewhere for the V6. Anyone want it?
d00012
PostPosted: Sun Jan 24, 2010 8:33 am    Post subject: Reply with quote
I'll take it if it's free... Laughing
Probably won't be any difference, right? They're mostly just paper-weights?
PostPosted: Sun Jan 24, 2010 8:47 am    Post subject: Reply with quote
Convert it to gen III aluminum heads. Then you can make some power.
d00012
PostPosted: Sun Jan 24, 2010 8:51 am    Post subject: Reply with quote
Yes, I've been reading into it a lot the past couple days. I was just at pull-a-part yesterday, LOTS of 3x00 motors that look clean.
I have a 3.4 from a 95 Camaro, so I have all the crank-trigger stuff for the DIS. It's just the computer I don't get. That's the only road block I've come to, everything else I can do easily.
I'll probably see around 170-200+ hp with the 3.4/3x00 hybrid.
PostPosted: Sun Jan 24, 2010 9:10 am    Post subject: Reply with quote
Why not just get an ECM and engine harness from a 3.4 pre-OBD2 4th gen F-body and just swap it out? Seems like the easiest route to me. Shrug
d00012
PostPosted: Sun Jan 24, 2010 9:53 am    Post subject: Reply with quote
If I come across one, I will. But having 3x00 heads would be really nice. Or did you mean get that ECM for the head swap?
PostPosted: Sun Jan 24, 2010 10:11 am    Post subject: Reply with quote
LOL then get angry when you still don't power and budget stuff in a BBC! Laughing
PostPosted: Sun Jan 24, 2010 10:17 am    Post subject: Reply with quote
Hehe, you caught me. The time and money spent on a 60V6 should really go towards a SBC.
Found the chip. It's a Hypertech PN 121331 SN 514488
1991 CAMARO/FIREBIRD 3.1 MPFI AUTO ST. RUN CAL-PAC CAR-SPECIAL - STAGE 1
d00012
PostPosted: Sun Jan 24, 2010 10:36 am    Post subject: Reply with quote
Wouldn't work for the 2.8 then?
That's why I bought a Firebird with a V8. Laughing
PostPosted: Sun Jan 24, 2010 11:05 am    Post subject: Reply with quote
It would work if you had the '91 SD computer. I converted mine, wasn't too hard.
d00012
PostPosted: Sun Jan 24, 2010 11:14 am    Post subject: Reply with quote
Oh, ok.
91camaro_rs
PostPosted: Sun Jan 24, 2010 11:46 pm    Post subject: Reply with quote
hmmm well i guess ill just keep it in even tho its probably not doing much of anything, i need to get a better job so i can get more money for an LS or something
