91camaro_rs Member
Posted: Sat Jan 23, 2010 10:55 pm Post subject: Jet Chips |
i have a stage 1 jet chip in my car, and i honestly dont recall why i put it in there and its been so long that i dont remember it making a difference, probably cause it didnt. anyone have any experience or knowledge with these and know if its even worth keeping it in the car _________________
izcain 9sec Club
Posted: Sat Jan 23, 2010 11:14 pm Post subject: |
Most of the time when you look at those chips and you compare fuel tables with stock ones they look almost identical. Not worth the money! _________________
9.17 @ 148 |
Posted: Sat Jan 23, 2010 11:37 pm Post subject: |
| izcain wrote: | | Not worth the money! |
Might net you a couple degrees of timing, and maybe turn your fans on sooner. That's about it. As long as there's no detonation, it should be fine to leave it in there.
You've got a V6 anyway. What kind of gains were you expecting to see?  |
d00012 Member
Posted: Sun Jan 24, 2010 8:33 am Post subject: |
I'll take it if it's free...
Probably won't be any difference, right? They're mostly just paper-weights? |
Posted: Sun Jan 24, 2010 8:47 am Post subject: |
| Convert it to gen III aluminum heads. Then you can make some power. |
d00012 Member
Posted: Sun Jan 24, 2010 8:51 am Post subject: |
Yes, I've been reading into it a lot the past couple days. I was just at pull-a-part yesterday, LOTS of 3x00 motors that look clean.
I have a 3.4 from a 95 Camaro, so I have all the crank-trigger stuff for the DIS. It's just the computer I don't get. That's the only road block I've come to, everything else I can do easily.
I'll probably see around 170-200+ hp with the 3.4/3x00 hybrid. |
Posted: Sun Jan 24, 2010 9:10 am Post subject: |
Why not just get an ECM and engine harness from a 3.4 pre-OBD2 4th gen F-body and just swap it out? Seems like the easiest route to me.  |
d00012 Member
Posted: Sun Jan 24, 2010 9:53 am Post subject: |
| If I come across one, I will. But having 3x00 heads would be really nice. Or did you mean get that ECM for the head swap? |
Posted: Sun Jan 24, 2010 10:11 am Post subject: |
| blue89 wrote: | | Convert it to gen III aluminum heads. Then you can make some power. |
LOL then get angry when you still don't power and budget stuff in a BBC!  _________________ A redline a day keeps the carbon away! |
Posted: Sun Jan 24, 2010 10:17 am Post subject: |
Hehe, you caught me. The time and money spent on a 60V6 should really go towards a SBC.
Found the chip. It's a Hypertech PN 121331 SN 514488
| Quote: | 1991 CAMARO/FIREBIRD 3.1 MPFI AUTO ST. RUN CAL-PAC CAR-SPECIAL - STAGE 1
d00012 Member
Posted: Sun Jan 24, 2010 10:36 am Post subject: |
Wouldn't work for the 2.8 then?
| Quote: | | Hehe, you caught me. The time and money spent on a 60V6 should really go towards a SBC. |
That's why I bought a Firebird with a V8.  |
Posted: Sun Jan 24, 2010 11:05 am Post subject: |
| It would work if you had the '91 SD computer. I converted mine, wasn't too hard. |
d00012 Member
Posted: Sun Jan 24, 2010 11:14 am Post subject: |
| Oh, ok. |
91camaro_rs Member
Posted: Sun Jan 24, 2010 11:46 pm Post subject: |
hmmm well i guess ill just keep it in even tho its probably not doing much of anything, i need to get a better job so i can get more money for an LS or something _________________
