MAF sensor
PostPosted: Mon Feb 01, 2010 12:44 am    Post subject: MAF sensor Reply with quote
Need one for an '87 LB9. My car don't do squat when I unplug it when it's in either open or closed loop.
PostPosted: Mon Feb 01, 2010 7:36 am    Post subject: Reply with quote
If the MAF is bad and you unplug it, the car should run better.
PostPosted: Mon Feb 01, 2010 8:34 am    Post subject: Reply with quote
Is the MAF getting power? A bad relay, or bad connection could cause that.
PostPosted: Mon Feb 01, 2010 9:14 am    Post subject: Reply with quote
Well if I start it unplugged it will run just the same as well, then if I plug it in it'll run like crap.
86toy
1986 Pontiac Trans Am
PostPosted: Tue Feb 02, 2010 9:57 am    Post subject: Reply with quote
check maf relay mine was bad and caused all kinds of damm problems lol,also check tps adjustment. Very Happy
86 t/a 305 tpi 700r4 3.73 possi 4 wheel disc
245/45/17 restoring
View user's profile Send private message Send e-mail Yahoo Messenger
