Posted: Mon Feb 01, 2010 12:44 am Post subject: MAF sensor |
Need one for an '87 LB9. My car don't do squat when I unplug it when it's in either open or closed loop. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Mon Feb 01, 2010 7:36 am Post subject: |
If the MAF is bad and you unplug it, the car should run better. _________________ A redline a day keeps the carbon away! |
Posted: Mon Feb 01, 2010 8:34 am Post subject: |
| Is the MAF getting power? A bad relay, or bad connection could cause that. |
Posted: Mon Feb 01, 2010 9:14 am Post subject: |
Well if I start it unplugged it will run just the same as well, then if I plug it in it'll run like crap. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
86toy Member
1986 Pontiac Trans Am
Posted: Tue Feb 02, 2010 9:57 am Post subject: |
check maf relay mine was bad and caused all kinds of damm problems lol,also check tps adjustment.  _________________ 86 t/a 305 tpi 700r4 3.73 possi 4 wheel disc
245/45/17 restoring |
