turbo_jimi Member
Posted: Sun Apr 04, 2010 12:42 pm Post subject: Free Chevy 307 |
Free Chevy 307, can be picked up at my house...intake manifold not included.
Thank you, _________________
Posted: Sun Apr 04, 2010 3:02 pm Post subject: |
I'll see if I can arrange pickup, can you give me a week or two? _________________
turbo_jimi Member
Posted: Sun Apr 04, 2010 6:51 pm Post subject: |
the 17th would be great! _________________
Posted: Sun Apr 04, 2010 8:10 pm Post subject: |
This was the engine that was going in my T/A until we found out it was a 307. It may be good as a core to be rebuilt, but it has been out in the elements for a while so there is quite a bit of rust on it. _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
turbo_jimi Member
Posted: Sun Apr 04, 2010 8:26 pm Post subject: |
heads are a little rusty, but we painted it early on and it does have the intake manifold on it, so not that bad _________________
Posted: Sun Apr 04, 2010 8:35 pm Post subject: |
Quite a bit of water probably got into the open manifold, the intake runners, and the open valves into the cylinders. I just don't wanna misrepresent this engine.  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Sun Apr 04, 2010 8:50 pm Post subject: |
will the crank rotate freely, or have you tried recently? _________________
turbo_jimi Member
Posted: Mon Apr 05, 2010 9:52 am Post subject: |
never tried it _________________
Posted: Mon Apr 05, 2010 5:52 pm Post subject: |
Go outside and try it!  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Mon Apr 05, 2010 6:14 pm Post subject: |
| Pour a little diesel or ATF down it tonight, then try it tomorrow. You'll have better luck. |
turbo_jimi Member
Posted: Mon Apr 05, 2010 6:26 pm Post subject: |
the wheel that the engine is sitting on is keeping the crank from turning _________________
Posted: Mon Apr 05, 2010 7:49 pm Post subject: |
I think I may have a truck to bring up and grab this. Basically what I'm interested in is the crank and possibly the rods. Realistically, I'll probably scrap the rest. _________________
Posted: Mon Apr 05, 2010 8:20 pm Post subject: |
I'm sure James' wife will appreciate getting it out of the yard!  |
turbo_jimi Member
Posted: Tue Apr 06, 2010 7:36 am Post subject: |
She sure will!  _________________
Posted: Tue Apr 06, 2010 7:40 am Post subject: |
| I would think a 307 would make a fine little flower pot. |
Posted: Tue Apr 06, 2010 3:06 pm Post subject: |
| Dewey316 wrote: | | I would think a 307 would make a fine little flower pot. |
I would at least hold a few more flowers than a 305. Flowers don't give a shizzle about stroke.
Their all about the bore!!
307 with 416 heads cut for 1.94" valves
XE262 cam
decent intake / carb / exhaust
easy 250 hp at the crank |
Posted: Tue Apr 06, 2010 3:16 pm Post subject: |
I'd say easy 250 at the wheels. _________________ A redline a day keeps the carbon away! |
Posted: Tue Apr 06, 2010 4:00 pm Post subject: |
| Twilightoptics wrote: | | I'd say easy 250 at the wheels. |
ehhh, I don't see that. That takes 1 per inch and those 416's aren't going to cut it there. |
Posted: Tue Apr 06, 2010 4:31 pm Post subject: |
| rjmcgee wrote: | | Twilightoptics wrote: | | I'd say easy 250 at the wheels. |
Well when stock 305s with decent stock cams put out 225 on the ground... I dont see why some decent 416s with bigger valves, and a performance cam couldn't squeek out 25hp without a sweat. _________________ A redline a day keeps the carbon away! |
Posted: Tue Apr 06, 2010 4:40 pm Post subject: |
| Torque would be down, hp up from a 305. Same cubes but alot less valve shrouding then the 305. I think it would make an interesting tpi experiment. |
