Project_1986_TA Member
Posted: Mon Sep 13, 2004 12:17 pm Post subject: Mastercylender |
I need a 4wheel disc break mastercylender for the t/a. The shop wanted to charge me $375 OTD for replacement.  _________________ Project_1986_TA
2K5 Yamaha R6- RIP
1986 Trans Am WS6-Sold  |
alloy T56 Elitist
Posted: Mon Sep 13, 2004 12:32 pm Post subject: |
If I recall correctly, a disk/disk master is no different thatn a disk/drum master. Any parts store should have them. And remember to bench bleed it before putting on the car. Otherwise you will never get all the air out of it.
Be a good time to flush the entire brake system also  |
Flyte risk Member
Posted: Mon Sep 13, 2004 5:25 pm Post subject: |
Actually, if I recall the thread from TGO correctly, disc/disc is different.
Disc/drum has a larger bore then disc/disc. The end result of the discussion was to the one that gave you what you wanted, disc/disc for better feel through the pedal or the disc/drum for less less effort. |
Posted: Mon Sep 13, 2004 6:20 pm Post subject: |
| Now if I remember correctly, lol.... Anyway, I think everybody's right. Early on the master cylinders were different. Then gm had pedal feel complaints and switched them all to the same master. |
Posted: Mon Sep 13, 2004 8:41 pm Post subject: |
| I was told by the guy at midas that it would require a special mastercylender because they were different from disc brakes to drum brakes. The entire break system was just flushed about 1 1/2 months ago. The shop wanted $248 for just the mastercylender, is that a good price? |
Posted: Tue Sep 14, 2004 1:00 pm Post subject: |
| Thanks for the link B. |
Posted: Thu Sep 16, 2004 3:00 pm Post subject: |
| Well im finally getting one. I called Napa but they had none in stock so i tried schucks and they had one for $38 w/ a lifetime warrenty. Now i just have to find some time to change the damn thing lol |
