Mastercylender
Project_1986_TA
PostPosted: Mon Sep 13, 2004 12:17 pm    Post subject: Mastercylender Reply with quote
I need a 4wheel disc break mastercylender for the t/a. The shop wanted to charge me $375 OTD for replacement. Shocked
Project_1986_TA
1999 Black Trans Am-Auto/ Stock
2K7 Yamaha R6S-Yoshimura Race Slip on
2K5 Yamaha R6- RIP Sad
1986 Trans Am WS6-Sold Sad
View user's profile Send private message Yahoo Messenger MSN Messenger
PostPosted: Mon Sep 13, 2004 12:32 pm    Post subject: Reply with quote
If I recall correctly, a disk/disk master is no different thatn a disk/drum master. Any parts store should have them. And remember to bench bleed it before putting on the car. Otherwise you will never get all the air out of it.
Be a good time to flush the entire brake system also Wink
Flyte risk
PostPosted: Mon Sep 13, 2004 5:25 pm    Post subject: Reply with quote
Actually, if I recall the thread from TGO correctly, disc/disc is different.
Disc/drum has a larger bore then disc/disc. The end result of the discussion was to the one that gave you what you wanted, disc/disc for better feel through the pedal or the disc/drum for less less effort.
PostPosted: Mon Sep 13, 2004 6:20 pm    Post subject: Reply with quote
Now if I remember correctly, lol.... Anyway, I think everybody's right. Early on the master cylinders were different. Then gm had pedal feel complaints and switched them all to the same master.
Project_1986_TA
PostPosted: Mon Sep 13, 2004 8:41 pm    Post subject: Reply with quote
I was told by the guy at midas that it would require a special mastercylender because they were different from disc brakes to drum brakes. The entire break system was just flushed about 1 1/2 months ago. The shop wanted $248 for just the mastercylender, is that a good price?
PostPosted: Mon Sep 13, 2004 8:53 pm    Post subject: Reply with quote
No.. just a quick check of the napaonline site got me this..
http://www.napaonline.com/cgi-bin/ncommerce3/ExecMacro/NAPAonline/search_results_cat.d2w/report?SUBMODEL=19%7CTrans+Am&BRAKE_SYSTEM=35%7C4+Wheel+Disc+Brakes&search_string=&org_string=
$29.99 if you dont mind a rebuilt unit. $104 for the 2nd line brand new. and $169 for the best brand new one.
Frankly the quality difference in the new ones is minimal.
Project_1986_TA
PostPosted: Tue Sep 14, 2004 1:00 pm    Post subject: Reply with quote
Thanks for the link B.
Project_1986_TA
PostPosted: Thu Sep 16, 2004 3:00 pm    Post subject: Reply with quote
Well im finally getting one. I called Napa but they had none in stock so i tried schucks and they had one for $38 w/ a lifetime warrenty. Now i just have to find some time to change the damn thing lol
