		jakemk8706 Member
   1991  Chevrolet  Camaro Z/28
				 Posted: Thu Sep 03, 2009 3:16 pm    Post subject: weird noises... |
				so i just finished up my clutch change, which went really smooth, and its definantly a huge improvement over a slipping clutch lol. but now i hear this clunking noise coming from my rear end area and thinking it could be my driveline or something. the noise happens when its in gear and i push in the clutch and shift. something feels loose kinda. i know i tightend all the bolts on the drive line. also when i had the torque arm off the rear end did rotate a little bit but it rotated back when i hooked the torque arm back up. or could it be a bad trans mount that got messed up during all this??? _________________ gas brake dip dip |
				 Posted: Thu Sep 03, 2009 5:09 pm    Post subject:  |
				| Throw a jack under the transmission (not the pan) and jack it up. If it moves up easily, the mount is shot. Get an Energy Suspension one from Schucks or Summit. |
		jakemk8706 Member
				 Posted: Thu Sep 03, 2009 6:12 pm    Post subject:  |
				its the same as the automatic mount right? _________________ gas brake dip dip |
				 Posted: Thu Sep 03, 2009 6:24 pm    Post subject:  |
				| Yup. Same mount for just about all Chebbies, and some Jeeps too I think. |
