weird noises...
jakemk8706
PostPosted: Thu Sep 03, 2009 3:16 pm    Post subject: weird noises... Reply with quote
so i just finished up my clutch change, which went really smooth, and its definantly a huge improvement over a slipping clutch lol. but now i hear this clunking noise coming from my rear end area and thinking it could be my driveline or something. the noise happens when its in gear and i push in the clutch and shift. something feels loose kinda. i know i tightend all the bolts on the drive line. also when i had the torque arm off the rear end did rotate a little bit but it rotated back when i hooked the torque arm back up. or could it be a bad trans mount that got messed up during all this???
gas brake dip dip
PostPosted: Thu Sep 03, 2009 5:09 pm    Post subject: Reply with quote
Throw a jack under the transmission (not the pan) and jack it up. If it moves up easily, the mount is shot. Get an Energy Suspension one from Schucks or Summit.
jakemk8706
PostPosted: Thu Sep 03, 2009 6:12 pm    Post subject: Reply with quote
its the same as the automatic mount right?
gas brake dip dip
PostPosted: Thu Sep 03, 2009 6:24 pm    Post subject: Reply with quote
Yup. Same mount for just about all Chebbies, and some Jeeps too I think.
