What else is needed for rear end rebuild?
PostPosted: Wed Aug 12, 2009 9:03 pm    Post subject: What else is needed for rear end rebuild? Reply with quote
I have new ring and pinion (3.73), new Eaton carrier, and axles on the way. Ring and pinion have the bearings and seals with it, but I understand that there is a shim kit which is used to properly set the gears, I didn't see one with the gear set. My axles will have the studs, bearings and seals when they arrive on Monday.
PostPosted: Fri Aug 14, 2009 8:44 am    Post subject: Reply with quote
I think if you go to pretty much any good parts store, they should have shims.
PostPosted: Fri Aug 14, 2009 9:37 am    Post subject: Reply with quote
Think I've got a bunch of shims yet.
PostPosted: Fri Aug 14, 2009 10:51 am    Post subject: Reply with quote
Cool, then after Monday I'll have everything I need (minus a diff cover - I can do later). Just need a convenient weekend to work on it Cool
PostPosted: Fri Aug 14, 2009 11:34 am    Post subject: Reply with quote
If you're coming down for the cruise on Sunday and don't happen to have a dial indicator for setting backlash, you can borrow mine.
PostPosted: Fri Aug 14, 2009 4:42 pm    Post subject: Reply with quote
Don't think I'll make the cruise. Going to try to make Pinks! tomorrow. Thanks for the offer, but not doing this on my own this time. This is a first for me and for this type of project, I'm a show me type - I learn better that way Cool Laughing
PostPosted: Fri Aug 14, 2009 5:22 pm    Post subject: Reply with quote
I've got access to a pinion depth gauge too. Don't know if it fits our old 10 bolts but we can sure try.
PostPosted: Sat Aug 22, 2009 3:24 pm    Post subject: Reply with quote
I picked up the side bearings for the posi today. Wasn't 100% positive on which set of the ones Eaton specified that I need, so I picked up a set of both. I asked before getting them if I could return the set I don't use. Now, except for special tools, I think I have everything I need, except for a convenient weekend Laughing
