Posted: Sun Jul 12, 2009 1:13 pm Post subject: Muffler length vs. noise |
Or just because you can fit a 2 foot muffler under your truck, should you?
http://www.summitracing.com/parts/MPE-12286/
Currently the stocker in it has a 20" case. That Magnaflow has a 24" case. Without the cat it looks like it should fit easily. I want the truck to be as quiet as possible without sacrificing flow (I've had my fill of loud cars on the freeway). Will that muffler be much quieter than a normal 16-18" case? |
Posted: Sun Jul 12, 2009 3:30 pm Post subject: |
A magnaflow is going to be a straight through design, which means no goofy baffles changing direction of flow like a typical case muffler.
I'd think it'd be about the same, but definitely better flow. _________________ A redline a day keeps the carbon away! |
Posted: Sun Jul 12, 2009 9:21 pm Post subject: |
Sweet. I'll snag that muffler and the Hedman headers off of Summit, and get some Remflex gaskets from Ian for it.
Now if only there was someone who had pipe and a welder, whose heads I had sitting in the back of the shop...  |
