HELP! my V6 wont start something is wrong
Goto page 1, 2, 3, 4  Next
91camaro_rs
PostPosted: Mon Aug 03, 2009 5:03 pm    Post subject: HELP! my V6 wont start something is wrong Reply with quote
ok i was driving it today and like .5 miles away from my house i go up a hill and it sputters a little bit and dies. i checked plugs and wires, some broke replaced them still no start. checked fuel...im getting fuel. checked fuses...all are good. i have no idea whats wrong with it, it was running fine yesterday. what do you guys think it is?
kurfbird
PostPosted: Mon Aug 03, 2009 5:31 pm    Post subject: Check Coil Reply with quote
Have you checked for spark??
Igntion Module
Coil
Pick up coil
kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
91camaro_rs
PostPosted: Mon Aug 03, 2009 8:53 pm    Post subject: Reply with quote
there is no spark...so idk how to check the ignition module, but i was gonna try a new coil tomorrow. the car turns over and everything just wont start
kurfbird
PostPosted: Mon Aug 03, 2009 8:58 pm    Post subject: Ignition module Reply with quote
I would lean torward and Igntion module. Have ahd them go bad. But it could be any of the three
Igntion module
Coil
Pick up Coil.
I woudl go for the igntion module first.
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
PostPosted: Mon Aug 03, 2009 9:04 pm    Post subject: Re: Ignition module Reply with quote
Igntion module
Coil
Pick up Coil.
Or worst case scenario, timing chain. Easy check is to pull the distributor cap, then crank the motor. If the rotor turns, the chain is fine. How many miles are on the car?
91camaro_rs
PostPosted: Mon Aug 03, 2009 9:12 pm    Post subject: Reply with quote
90k on a rebuilt motor
how do i check the ignition module
kurfbird
PostPosted: Mon Aug 03, 2009 9:35 pm    Post subject: NO spark Reply with quote
Take the igntion moudle to autozone shucks Napa and they can test it for you.
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
91camaro_rs
PostPosted: Mon Aug 03, 2009 9:37 pm    Post subject: Reply with quote
haha better question...what and where is the ignition module
PostPosted: Mon Aug 03, 2009 9:53 pm    Post subject: Reply with quote
it is an electronic "thingie" underneath the distributor cap. you know where you connect the small wires (not plug wires) to your dizzy? THAT is the ICM. the pickup coil connects to it.
it's the black thing.
91camaro_rs
PostPosted: Mon Aug 03, 2009 10:40 pm    Post subject: Reply with quote
well i guess i just gonna have to get that and a new coil and see what happens
91camaro_rs
PostPosted: Tue Aug 04, 2009 1:03 pm    Post subject: Re: Ignition module Reply with quote
Al Hasse wrote:
Igntion module
Coil
Pick up Coil.
well worst case scenario just happened, rotor didnt turn, checked the gear on distributor and cam and they are ok, so what do i do with the timing chain? did it break?
PostPosted: Tue Aug 04, 2009 2:37 pm    Post subject: Reply with quote
I was pretty sure your timing chain would be fine. The timing set probably has nylon tips on the gear teeth to make them quiet, the nylon more than likely wore down enough for the chain to slip off the gears. That's what happened with mine at the 200K mile mark. New timing set and you should be fine, these 60* V6 motors are non-interference, so the pistons won't hit any open valves.
91camaro_rs
PostPosted: Tue Aug 04, 2009 2:43 pm    Post subject: Reply with quote
ok just for assurance...aaron said that i dont have to take the water pump off, and that some bolts hold the water pump to the cover, so what bolts do i leave alone...the small ones?
PostPosted: Tue Aug 04, 2009 2:49 pm    Post subject: Reply with quote
You can take the timing cover and water pump off as a unit. Without looking (I'm at work and the V6 car is at home), I couldn't say which bolts to leave, but obviously the ones around the perimeter of the cover come out. Oh...you also need to replace the oil seal on the crankshaft, it's a press fit into the timing cover - be sure to put some oil on it before you slide it over the crank or you'll end up ripping it (ask me how I know Laughing )
PostPosted: Tue Aug 04, 2009 2:51 pm    Post subject: Reply with quote
He's right, you should be able to pull the timing cover with the water pump attached. Leave all the bolts holding the pump to the cover.
'88 FORMULA
91camaro_rs
PostPosted: Tue Aug 04, 2009 2:58 pm    Post subject: Reply with quote
ok sweet, so i need gears and a chain and an oil seal. do i gotta drain the coolant and the oil?
PostPosted: Tue Aug 04, 2009 3:04 pm    Post subject: Reply with quote
I know on the V8 you don't loose any oil pulling the timing cover but on the six, I think you'll wanna dump it, and since the water pump is coming off, Id definetly drain the coolant too, unless you like the mess. lol
kurfbird
PostPosted: Tue Aug 04, 2009 5:14 pm    Post subject: drain the collant Reply with quote
drain the collant. I would change the oil and filter when your done
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
PostPosted: Tue Aug 04, 2009 5:21 pm    Post subject: Reply with quote
Coolant comes out for sure. Oil is a tossup. The 60* motors have a timing chain that's open to the oil pan (an idea Chevy shamelessly ripped off from the FE Ford, BTW Very Happy). That means that anything you drop (screws, dirt, coolant) ends up in the oil. Personally, I would dump it.
In the FelPro chain cover kit I bought, they recommend cutting the oil pan gasket, and replacing the front section of it. IMHO that's kinda bogus. I hit the bottom of the chain cover with some Ultra Black RTV, and dropped it back down over the cleaned oil pan gasket. Been working fine since.
PostPosted: Tue Aug 04, 2009 6:03 pm    Post subject: Reply with quote
Here's a list of parts you should need for the job. I pulled them from the NAPA site, but should be available at most other stores. As for special tools, you'll need a harmonic balancer puller (I have one, but I'll have to look) and a torque wrench (I also have).
Timing set
http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=NTP&PartNumber=203067&Description=Timing+Set+-+3+Piece
Gaskets, this kit has all that you should need, even the water pump gasket. (I don't see the section for the oil pan in the kit shown though).
http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=FPG&PartNumber=TCS45828&Description=Timing+Cover+Gasket+Set
Timing cover seal
http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=NOS&PartNumber=17286&Description=Timing+Cover+Seal
Timing chain damper (if the chain came off, this probably isn't in the best of shape any more)
http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=NTP&PartNumber=95059&Description=Timing+Chain+Damper
If I missed anything, someone else may chime in.
Page 1 of 4
