91camaro_rs Member
Posted: Mon Aug 03, 2009 5:03 pm Post subject: HELP! my V6 wont start something is wrong |
| ok i was driving it today and like .5 miles away from my house i go up a hill and it sputters a little bit and dies. i checked plugs and wires, some broke replaced them still no start. checked fuel...im getting fuel. checked fuses...all are good. i have no idea whats wrong with it, it was running fine yesterday. what do you guys think it is? |
kurfbird Member
Posted: Mon Aug 03, 2009 5:31 pm Post subject: Check Coil |
Have you checked for spark??
Igntion Module
Coil
Pick up coil _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
91camaro_rs Member
Posted: Mon Aug 03, 2009 8:53 pm Post subject: |
| there is no spark...so idk how to check the ignition module, but i was gonna try a new coil tomorrow. the car turns over and everything just wont start |
kurfbird Member
Posted: Mon Aug 03, 2009 8:58 pm Post subject: Ignition module |
I would lean torward and Igntion module. Have ahd them go bad. But it could be any of the three
Igntion module
Coil
Pick up Coil.
I woudl go for the igntion module first. _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
Posted: Mon Aug 03, 2009 9:04 pm Post subject: Re: Ignition module |
| kurfbird wrote: | I would lean torward and Igntion module. Have ahd them go bad. But it could be any of the three
Igntion module
Coil
Pick up Coil.
I woudl go for the igntion module first. |
Or worst case scenario, timing chain. Easy check is to pull the distributor cap, then crank the motor. If the rotor turns, the chain is fine. How many miles are on the car? _________________ 92 Camaro
91camaro_rs Member
Posted: Mon Aug 03, 2009 9:12 pm Post subject: |
90k on a rebuilt motor
how do i check the ignition module |
kurfbird Member
Posted: Mon Aug 03, 2009 9:35 pm Post subject: NO spark |
Take the igntion moudle to autozone shucks Napa and they can test it for you. _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
91camaro_rs Member
Posted: Mon Aug 03, 2009 9:37 pm Post subject: |
| haha better question...what and where is the ignition module |
Posted: Mon Aug 03, 2009 9:53 pm Post subject: |
it is an electronic "thingie" underneath the distributor cap. you know where you connect the small wires (not plug wires) to your dizzy? THAT is the ICM. the pickup coil connects to it.
it's the black thing.
 _________________ 86' firebird (Junked in 2015). 88' GTA (sold in 2020).
91camaro_rs Member
Posted: Mon Aug 03, 2009 10:40 pm Post subject: |
| well i guess i just gonna have to get that and a new coil and see what happens |
91camaro_rs Member
Posted: Tue Aug 04, 2009 1:03 pm Post subject: Re: Ignition module |
| Al Hasse wrote: | | kurfbird wrote: | I would lean torward and Igntion module. Have ahd them go bad. But it could be any of the three
Igntion module
Coil
Pick up Coil.
Or worst case scenario, timing chain. Easy check is to pull the distributor cap, then crank the motor. If the rotor turns, the chain is fine. How many miles are on the car? |
well worst case scenario just happened, rotor didnt turn, checked the gear on distributor and cam and they are ok, so what do i do with the timing chain? did it break? |
Posted: Tue Aug 04, 2009 2:37 pm Post subject: |
I was pretty sure your timing chain would be fine. The timing set probably has nylon tips on the gear teeth to make them quiet, the nylon more than likely wore down enough for the chain to slip off the gears. That's what happened with mine at the 200K mile mark. New timing set and you should be fine, these 60* V6 motors are non-interference, so the pistons won't hit any open valves. _________________ 92 Camaro
91camaro_rs Member
Posted: Tue Aug 04, 2009 2:43 pm Post subject: |
| ok just for assurance...aaron said that i dont have to take the water pump off, and that some bolts hold the water pump to the cover, so what bolts do i leave alone...the small ones? |
Posted: Tue Aug 04, 2009 2:49 pm Post subject: |
You can take the timing cover and water pump off as a unit. Without looking (I'm at work and the V6 car is at home), I couldn't say which bolts to leave, but obviously the ones around the perimeter of the cover come out. Oh...you also need to replace the oil seal on the crankshaft, it's a press fit into the timing cover - be sure to put some oil on it before you slide it over the crank or you'll end up ripping it (ask me how I know ) |
fiveoformula Member
Posted: Tue Aug 04, 2009 2:51 pm Post subject: |
He's right, you should be able to pull the timing cover with the water pump attached. Leave all the bolts holding the pump to the cover. _________________
'88 FORMULA |
91camaro_rs Member
Posted: Tue Aug 04, 2009 2:58 pm Post subject: |
| ok sweet, so i need gears and a chain and an oil seal. do i gotta drain the coolant and the oil? |
fiveoformula Member
Posted: Tue Aug 04, 2009 3:04 pm Post subject: |
| I know on the V8 you don't loose any oil pulling the timing cover but on the six, I think you'll wanna dump it, and since the water pump is coming off, Id definetly drain the coolant too, unless you like the mess. lol |
kurfbird Member
Posted: Tue Aug 04, 2009 5:14 pm Post subject: drain the collant |
drain the collant. I would change the oil and filter when your done _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
Posted: Tue Aug 04, 2009 5:21 pm Post subject: |
Coolant comes out for sure. Oil is a tossup. The 60* motors have a timing chain that's open to the oil pan (an idea Chevy shamelessly ripped off from the FE Ford, BTW ). That means that anything you drop (screws, dirt, coolant) ends up in the oil. Personally, I would dump it.
In the FelPro chain cover kit I bought, they recommend cutting the oil pan gasket, and replacing the front section of it. IMHO that's kinda bogus. I hit the bottom of the chain cover with some Ultra Black RTV, and dropped it back down over the cleaned oil pan gasket. Been working fine since. |
