3.5" exhaust routing
PostPosted: Thu Jun 25, 2009 9:34 am    Post subject: 3.5" exhaust routing Reply with quote
So I have been working on getting the exhaust routed on the camaro. There is an amazing amount of room! I am putting a coupler above the axle so I won't have to drop it to install the pipe when it's done. Everything fits great and feel confident I can stuff a single 4" in there if I need to later on. I'll post a picture later when I have a chance. I'm not using a muffler and the tip is coming out of the passenger side. Should be heard loud and clear!
PostPosted: Thu Jun 25, 2009 9:45 am    Post subject: Reply with quote
Red X
Very Happy
I took the easy way out and just dumped it in front of the tire.
PostPosted: Thu Jun 25, 2009 10:08 am    Post subject: Reply with quote
lol, did you sacrifice ground clearance? i cant wait for the wagon wheels. It will be like driving a 4x4!
PostPosted: Thu Jun 25, 2009 11:36 am    Post subject: Reply with quote
Yes. It's lower than what I had. I know I'll scrape but I'm okay with that. Under the car it's a 1/4"-1/2" lower than my SFCs and then about the same where the tip exits at the rear of the door. I ovaled a 3.5" section of pipe for the tip.
Wagons are just waiting for you man. Laughing
redlava
PostPosted: Thu Jun 25, 2009 6:22 pm    Post subject: Reply with quote
blue you should be able to fit a 4 inch in there like your saying, mufflex makes a direct fit setup for a thirdgen.
