Posted: Thu Jun 25, 2009 9:34 am Post subject: 3.5" exhaust routing |
So I have been working on getting the exhaust routed on the camaro. There is an amazing amount of room! I am putting a coupler above the axle so I won't have to drop it to install the pipe when it's done. Everything fits great and feel confident I can stuff a single 4" in there if I need to later on. I'll post a picture later when I have a chance. I'm not using a muffler and the tip is coming out of the passenger side. Should be heard loud and clear! _________________ E30
Posted: Thu Jun 25, 2009 9:45 am Post subject: |
I took the easy way out and just dumped it in front of the tire. _________________
Posted: Thu Jun 25, 2009 10:08 am Post subject: |
| lol, did you sacrifice ground clearance? i cant wait for the wagon wheels. It will be like driving a 4x4! |
Posted: Thu Jun 25, 2009 11:36 am Post subject: |
Yes. It's lower than what I had. I know I'll scrape but I'm okay with that. Under the car it's a 1/4"-1/2" lower than my SFCs and then about the same where the tip exits at the rear of the door. I ovaled a 3.5" section of pipe for the tip.
Wagons are just waiting for you man.  |
redlava Member
Posted: Thu Jun 25, 2009 6:22 pm Post subject: |
| blue you should be able to fit a 4 inch in there like your saying, mufflex makes a direct fit setup for a thirdgen. |
