91camaro_rs Member
Posted: Mon May 18, 2009 3:28 pm Post subject: hazards not working |
| anyone have any idea why my hazards dont work? i made sure that the fuse was good, idk what else to check |
mrpopo573 Member
Posted: Mon May 18, 2009 3:57 pm Post subject: |
Your flasher/blinker module is out. Buy a new one and install, its under your dash on/near the fuse panel and is usually square or cylindrical.
I haven't had a thirdgen in a while, but its an easy fix. It plugs right in _________________
2000 Maxima SE 5 Speed VQ30
Posted: Mon May 18, 2009 4:52 pm Post subject: |
| Should be two in the fusebox. One for blinkers, one for hazards. You can swap them to test the circuits, but IIRC you don't want to leave them since your blinker speed will be affected. |
91camaro_rs Member
Posted: Mon May 18, 2009 9:36 pm Post subject: |
| where do i get a new one? |
mrpopo573 Member
Posted: Mon May 18, 2009 9:39 pm Post subject: |
Napa, westbay, action auto parts, schucks........ _________________
Posted: Mon May 18, 2009 11:18 pm Post subject: |
Gotta love Chevy for that. Flasher module for my former POS Thunderbird was $65 and only available from Motorcraft (no aftermarket ones that I could find). I tore apart the old one out of curiosity; more stuff in there than the godamned space shuttle.  |
