hazards not working
91camaro_rs
PostPosted: Mon May 18, 2009 3:28 pm    Post subject: hazards not working Reply with quote
anyone have any idea why my hazards dont work? i made sure that the fuse was good, idk what else to check
mrpopo573
PostPosted: Mon May 18, 2009 3:57 pm    Post subject: Reply with quote
Your flasher/blinker module is out. Buy a new one and install, its under your dash on/near the fuse panel and is usually square or cylindrical.
I haven't had a thirdgen in a while, but its an easy fix. It plugs right in
305302eater wrote:
2000 Maxima SE 5 Speed VQ30
PostPosted: Mon May 18, 2009 4:52 pm    Post subject: Reply with quote
Should be two in the fusebox. One for blinkers, one for hazards. You can swap them to test the circuits, but IIRC you don't want to leave them since your blinker speed will be affected.
91camaro_rs
PostPosted: Mon May 18, 2009 9:36 pm    Post subject: Reply with quote
where do i get a new one?
mrpopo573
PostPosted: Mon May 18, 2009 9:39 pm    Post subject: Reply with quote
Napa, westbay, action auto parts, schucks........
PostPosted: Mon May 18, 2009 10:07 pm    Post subject: Reply with quote
http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=NF&PartNumber=LF12&Description=Flasher+-+Hazard
Only difference between this and the stocker is the casing. Stock one will be a silver metal case instead of the plastic one here.
PostPosted: Mon May 18, 2009 11:18 pm    Post subject: Reply with quote
Gotta love Chevy for that. Flasher module for my former POS Thunderbird was $65 and only available from Motorcraft (no aftermarket ones that I could find). I tore apart the old one out of curiosity; more stuff in there than the godamned space shuttle. Rolling Eyes
