clutch question
HONDASLAYER
PostPosted: Mon Aug 24, 2009 5:18 pm    Post subject: clutch question Reply with quote
Ok i really need a clutch kit BAD now. When looking for a clutch kit online what spline count do i need to look for? Confused
<div>Quizzes Girls Games</div>
PostPosted: Mon Aug 24, 2009 5:53 pm    Post subject: Reply with quote
Your year make and model and engine.
It's 26spline but you need to get it for your car to avoid problems. Stay away from centerforce.
HONDASLAYER
PostPosted: Mon Aug 24, 2009 6:19 pm    Post subject: Reply with quote
i think i'm going to go with either the borg warner brute force or the zoom.
which one do you think???
PostPosted: Mon Aug 24, 2009 6:32 pm    Post subject: Reply with quote
Neither. I like Spec.
HONDASLAYER
PostPosted: Mon Aug 24, 2009 7:10 pm    Post subject: Reply with quote
where can i get spec ?
PostPosted: Mon Aug 24, 2009 7:18 pm    Post subject: Reply with quote
http://www.specclutch.com/
If you're going to go cheap, just get an Napa clutch or something. Centerforce/ect. are garbage. Throwing good money on a basically stock clutch.
HONDASLAYER
PostPosted: Mon Aug 24, 2009 7:24 pm    Post subject: Reply with quote
unfortunatly i'm not made of money. So spec is out. But is a brute force better or worse than a napa or smucks brand?
PostPosted: Mon Aug 24, 2009 7:28 pm    Post subject: Reply with quote
Had Centeforce in my IROC, Schucks brand in my Blazer, Autozone brand in my S10. The difference was negligible between the three IMHO. All launched decent but not great.
Never heard of "Brute Force" so I couldn't advise you on that one.
HONDASLAYER
PostPosted: Mon Aug 24, 2009 7:30 pm    Post subject: Reply with quote
brute force is made by borge warner, same as my tranny.
PostPosted: Mon Aug 24, 2009 7:35 pm    Post subject: Reply with quote
The Borg-Warner that built the NWC T-5 is no longer the same company that makes that clutch. Laughing There is no correlation between the two.
HONDASLAYER
PostPosted: Mon Aug 24, 2009 7:39 pm    Post subject: Reply with quote
oh..... Embarassed
PostPosted: Mon Aug 24, 2009 7:49 pm    Post subject: Reply with quote
I had a Zoom clutch installed by Firestone in my 89 shortly after I bought it. Mine is a bit better than stock, I've been pretty happy with it, but now I think the throw out bearing is wearing out (squeeksqueeksqueek until I put a little pressure on the clutch pedal) Mechanic told me it was a street/strip clutch.
PostPosted: Tue Aug 25, 2009 7:01 am    Post subject: Reply with quote
I had a Zoom MU stock replacement style clutch from Summit. It was great for $89. Held up to my ~250whp for almost 3 years. No slip.
Al, the squeaksqueaksqueak might be the pivot ball that your clutch fork rides on. I had that problem, a little white lithium grease where the pivot ball meets the fork solved it permanently so far. Just gotta peel the dust cover back a bit.
PostPosted: Tue Aug 25, 2009 9:52 am    Post subject: Reply with quote
+1 on that. It's a fairly well known issue with those. When I bought my S10 clutch there was a warning paper about it thrown into the box. Like a dumbass I ignored, and mine does the same thing sometimes at idle. Rolling Eyes
PostPosted: Tue Aug 25, 2009 12:24 pm    Post subject: Reply with quote
Hmm Always seen the squeal with a hydro setup clutch out to be the TO bearing. Push clutch in, squeek goes away.
PostPosted: Tue Aug 25, 2009 2:53 pm    Post subject: Reply with quote
Pushing the clutch in puts pressure on the pivot ball, stopping the squeak. Either way, it's cheaper and easier just to grease that pivot ball and see if it helps. Both of my Camaros have had this exact same problem and it was always the pivot.
If it doesn't help, you're one step closer to finding the problem, now likely to be the TOB. Wink
