"Logging"
PostPosted: Sun May 03, 2009 2:53 pm    Post subject: "Logging" Reply with quote
I was out "logging" Laughing today. Dragging some nice alder trees out that the snow storm collapsed this winter. Since the newer tractor (its a late 50s model) currently needs an oil change(full of water from sitting outside all winter) I fired up the antique. It's a 1939 farmall M. Top speed 16.2mph, 26hp 4cylinder, 1495rpm redline, and will pull 4200lbs in 1st gear.. Talk about gearing! It's kinda fun. At one point I was pulling 4 logs and the thing didnt even grunt. These are the tree tops in the pic. Laughing
PostPosted: Sun May 03, 2009 4:41 pm    Post subject: Reply with quote
i've used one of those tractors of the same year back when i lived in the boondocks of wisconsin their awsome for hauling wood
PostPosted: Sun May 03, 2009 5:19 pm    Post subject: Reply with quote
Can you pop a wheelie? Laughing
That thing is kind of cool!
PostPosted: Sun May 03, 2009 5:41 pm    Post subject: Reply with quote
back when stuff was built right!!!
PostPosted: Sun May 03, 2009 8:09 pm    Post subject: Reply with quote
Wouldnt try, but they were known for flipping over and killing people. One of the reasons new ones are required to have ROPS. Was reading today that the coil spring that holds the seat up occasionally breaks.. tipping the seat over and dropping you into the implement.. Shocked So even though the things 70 years old and still works, they didnt quite have everything figured out.
PostPosted: Sun May 03, 2009 11:26 pm    Post subject: Reply with quote
i have on accident dumped the clutch on it an got the front wheels totally sideways Rolling Eyes had to carefully dump the clutch again to get em strait dam huge logs Embarassed but thats what you get when a 12 year old operates a tractor with no supervision
PostPosted: Mon May 04, 2009 7:55 pm    Post subject: Reply with quote
so cool Brandon! can we do burnouts in that?!
