Posted: Sun May 03, 2009 2:53 pm Post subject: "Logging" |
I was out "logging" today. Dragging some nice alder trees out that the snow storm collapsed this winter. Since the newer tractor (its a late 50s model) currently needs an oil change(full of water from sitting outside all winter) I fired up the antique. It's a 1939 farmall M. Top speed 16.2mph, 26hp 4cylinder, 1495rpm redline, and will pull 4200lbs in 1st gear.. Talk about gearing! It's kinda fun. At one point I was pulling 4 logs and the thing didnt even grunt. These are the tree tops in the pic.
GREG DAVIDSON Member
Posted: Sun May 03, 2009 4:41 pm Post subject: |
| i've used one of those tractors of the same year back when i lived in the boondocks of wisconsin their awsome for hauling wood |
Posted: Sun May 03, 2009 5:19 pm Post subject: |
Can you pop a wheelie?
That thing is kind of cool! _________________
Posted: Sun May 03, 2009 5:41 pm Post subject: |
| back when stuff was built right!!! |
Posted: Sun May 03, 2009 8:09 pm Post subject: |
| iansane wrote: | Can you pop a wheelie?
That thing is kind of cool! |
Wouldnt try, but they were known for flipping over and killing people. One of the reasons new ones are required to have ROPS. Was reading today that the coil spring that holds the seat up occasionally breaks.. tipping the seat over and dropping you into the implement.. So even though the things 70 years old and still works, they didnt quite have everything figured out. |
Posted: Sun May 03, 2009 11:26 pm Post subject: |
i have on accident dumped the clutch on it an got the front wheels totally sideways had to carefully dump the clutch again to get em strait dam huge logs but thats what you get when a 12 year old operates a tractor with no supervision |
Posted: Mon May 04, 2009 7:55 pm Post subject: |
so cool Brandon! can we do burnouts in that?!
