jakemk8706 Member
Posted: Thu Apr 09, 2009 1:50 pm Post subject: |
Stock clutches will handle 250hp just fine. Get something better only if you plan on considerably more power. I'm using spec's second line. One up from stock and my axle twisted before the clutch slipped. _________________ A redline a day keeps the carbon away! |
Posted: Thu Apr 09, 2009 2:11 pm Post subject: |
Paul is right, I ran that clutch when I first did the 5 spd in my car. It was fine until I did exhaust, that night it started to slip. Of course I do thing back asswards and probably picked up 50 hp at the wheels when I did exhaust.  |
Posted: Thu Apr 09, 2009 2:54 pm Post subject: |
The clutch in my 89 is a Zoom Street/Strip. It was installed shortly after I bought the car. Takes a bit more effort than stock, but not too uncomfortable, unless you're at a very long red light _________________ 92 Camaro
Posted: Thu Apr 09, 2009 4:59 pm Post subject: |
| Al Hasse wrote: | | The clutch in my 89 is a Zoom Street/Strip. It was installed shortly after I bought the car. Takes a bit more effort than stock, but not too uncomfortable, unless you're at a very long red light |
In which case you should be in neutral with your foot off the clutch to increase throw out bearing life!  _________________ A redline a day keeps the carbon away! |
Posted: Thu Apr 09, 2009 6:05 pm Post subject: |
| Twilightoptics wrote: | | Al Hasse wrote: | | The clutch in my 89 is a Zoom Street/Strip. It was installed shortly after I bought the car. Takes a bit more effort than stock, but not too uncomfortable, unless you're at a very long red light |
In which case you should be in neutral with your foot off the clutch to increase throw out bearing life!  |
That is the general practice, not only does it save the throw out bearing, but also the leg  |
Posted: Thu Apr 09, 2009 7:11 pm Post subject: |
I wish my clutch was going out... _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
fiveoformula Member
Posted: Thu Apr 09, 2009 8:41 pm Post subject: |
| DBL_TKE wrote: | | I wish my clutch was going out... |
Poor Skyler....
Can't kill a 700R4.  |
Posted: Thu Apr 09, 2009 10:43 pm Post subject: |
| fiveoformula wrote: | | DBL_TKE wrote: | | I wish my clutch was going out... |
Poor Skyler....
Sounds like you're not trying hard enough.  |
Posted: Fri Apr 10, 2009 6:38 am Post subject: |
centerforce is nothing special. get a stocker, or get a spec. i have a spec lvl1 in my v6 car and that is a GREAT clutch. the centerforce in my GTA feels no different then a stock clutch, but the clutch in the little six takes the abuse.
do not get a parts store clutch. |
Posted: Fri Apr 10, 2009 6:49 am Post subject: |
| Xophertony wrote: |
Why not? _________________ A redline a day keeps the carbon away! |
Posted: Fri Apr 10, 2009 4:17 pm Post subject: |
| Xophertony wrote: | | do not get a parts store clutch. |
Wha? Most are made by Valeo anyways. Same company that makes GMs friction, including the new ZR1. (which oddly enough is a Sachs PP and Valeo disc!) _________________
Posted: Fri Apr 10, 2009 4:31 pm Post subject: |
Tony had one come apart remember.
But we see very few clutch returns. I'd definatly spend the few $$ extra for a new over a remanufactured though. The price difference is negligible for what you get. |
Posted: Fri Apr 10, 2009 9:47 pm Post subject: |
| iansane wrote: | | Xophertony wrote: | | do not get a parts store clutch. |
Wha? Most are made by Valeo anyways. Same company that makes GMs friction, including the new ZR1. (which oddly enough is a Sachs PP and Valeo disc!) |
Pressure plate for the Centerforce LT1 clutch and the parts store Blazer clutch were both stamped Valeo, as I recall. For whatever it's worth.  |
Posted: Fri Apr 10, 2009 10:16 pm Post subject: |
Being manufactured by the same company, does not equate to the same quality of matterials, quality of manufacturing, or quality control.
Not that I have any tech to bring, but I'm just saying. |
Posted: Sat Apr 11, 2009 9:49 am Post subject: |
| As far as I could tell the centerforce pressure plates the same as stock, with the weights added. I think most of the upgrade is in the disc on those. Of course you can't see spring pressure either. I do know they're both Valeo. Most of the stuff is made in china now too. |
