90droptoproc Member
Posted: Tue Apr 07, 2009 2:32 pm Post subject: bell housing ?? |
will a bell housing for a T10 work for a T5?
thanks _________________
Posted: Tue Apr 07, 2009 4:43 pm Post subject: |
Depends on your application.
If you want to put a T5 where a T10 was then yes. Custom cross member obviously etc. 26 spline clutch disc.
If you can't find a T5 bellhousing and have access to a T10 housing then no. Only the T5 housing has a provision for the Hydraulic Slave '84 and newer.
If you mate a T5 to the Muncie/T10 you have to drill the T5 housing out to 1/2" bolts for the Std Bell. _________________ A redline a day keeps the carbon away! |
90droptoproc Member
Posted: Tue Apr 07, 2009 4:51 pm Post subject: |
a friend of mine with a circle track shop is liquidating some spare parts and there is a real nice T10 bellhousing for the 7 inch clutches and has a hydrolic throw out bearing in it already, its all after market and they are running 6 inch clutches in it now over 600 hp
but they are going with an internal clutch trans which requires a new bell housing
so I was wondering if the bolt pattern and such would work with a T5, and also I guess if the 4th gen hydrolic throwout setup will work with a T5 also
Thanks for the responce Paul!
Rich |
Posted: Tue Apr 07, 2009 4:57 pm Post subject: |
Was the T10 tilted or straight?
I thought they were installed straight up which would make it a no go for an F body T5 because of the angle they are installed at. |
90droptoproc Member
Posted: Tue Apr 07, 2009 9:20 pm Post subject: |
good call, thanks, it's straight up, thanks for the help _________________
Posted: Tue Apr 07, 2009 9:54 pm Post subject: |
That's part of what I was getting at too. Was at work and didn't have time to elaborate.
F-Body T5's are tilted. Only trans to be tilted.
T56/T10/Muncie/Saginaw etc are all straight up.
We sell alot of T5's and converted V8 T5's w/ S10 tails to hotrodders with Muncie Bellhousings for Model A type hotrods. _________________ A redline a day keeps the carbon away! |
