HVAC controller
PostPosted: Sun Feb 15, 2009 4:28 pm    Post subject: HVAC controller Reply with quote
Since I have the dash apart, I may as well put this out. I think the vacuum selector on my HVAC controller is acting up, also one of it's mounting tabs is broken. I need one from an A/C car, if there is a difference between A/C and non-A/C.
PostPosted: Sun Feb 15, 2009 4:40 pm    Post subject: Reply with quote
if the firebird ones the same i might have what your looking for in my 89 parts car
PostPosted: Sun Feb 15, 2009 5:12 pm    Post subject: Reply with quote
Probably the same. Mode control on the faceplate look the same, so stands to reason that vacuum switch should be too.
I'll look at the junk yard tomorrow if they're open.
PostPosted: Sun Feb 15, 2009 5:17 pm    Post subject: Reply with quote
ok just let me know if you cant find one and i'll bring it up this weekend
PostPosted: Sun Feb 15, 2009 7:05 pm    Post subject: Reply with quote
Al,
Could you snap a picture of what you need? I think I may have it with the HVAC stuff I pulled out of the orginal dash for the Berlinetta.
PostPosted: Sun Feb 15, 2009 7:30 pm    Post subject: Reply with quote
The piece that connects to the vacuum manifold. mine has a broken tab, also seems to route air to the wrong places, but disassembled its diaphragm looks OK. Maybe I have an incorrect one??
PostPosted: Sun Feb 15, 2009 9:45 pm    Post subject: Reply with quote
Figured out the problem, but I'm still in need of one. This one will work until then.
PostPosted: Mon Feb 16, 2009 6:45 pm    Post subject: Reply with quote
I definately have it Al.
but you have to take it with all the vaccum lines attached. Razz
If you can wait until dyno, its yours.
PostPosted: Mon Feb 16, 2009 6:58 pm    Post subject: Reply with quote
Thanks. Mine works pretty good for now, but with the broken mount, it will leak. I'll take it at dyno Cool
PostPosted: Tue Feb 24, 2009 4:17 pm    Post subject: Reply with quote
you want a digital hvac controller from a 87 gta dont you? and put coloured LED's for temp and fan speed huh it be tricked out.
PostPosted: Tue Feb 24, 2009 7:14 pm    Post subject: Reply with quote
Laughing Laughing Laughing
