Posted: Sun Feb 15, 2009 4:28 pm Post subject: HVAC controller |
Since I have the dash apart, I may as well put this out. I think the vacuum selector on my HVAC controller is acting up, also one of it's mounting tabs is broken. I need one from an A/C car, if there is a difference between A/C and non-A/C. _________________ 92 Camaro
GREG DAVIDSON Member
Posted: Sun Feb 15, 2009 4:40 pm Post subject: |
| if the firebird ones the same i might have what your looking for in my 89 parts car |
Posted: Sun Feb 15, 2009 5:12 pm Post subject: |
Probably the same. Mode control on the faceplate look the same, so stands to reason that vacuum switch should be too.
I'll look at the junk yard tomorrow if they're open. |
Posted: Sun Feb 15, 2009 5:17 pm Post subject: |
| ok just let me know if you cant find one and i'll bring it up this weekend |
Posted: Sun Feb 15, 2009 7:05 pm Post subject: |
Al,
Could you snap a picture of what you need? I think I may have it with the HVAC stuff I pulled out of the orginal dash for the Berlinetta. _________________
Posted: Sun Feb 15, 2009 7:30 pm Post subject: |
The piece that connects to the vacuum manifold. mine has a broken tab, also seems to route air to the wrong places, but disassembled its diaphragm looks OK. Maybe I have an incorrect one??
Posted: Sun Feb 15, 2009 9:45 pm Post subject: |
| Figured out the problem, but I'm still in need of one. This one will work until then. |
Posted: Mon Feb 16, 2009 6:45 pm Post subject: |
I definately have it Al.
but you have to take it with all the vaccum lines attached.
If you can wait until dyno, its yours. _________________
Posted: Mon Feb 16, 2009 6:58 pm Post subject: |
Thanks. Mine works pretty good for now, but with the broken mount, it will leak. I'll take it at dyno  |
BigDaddyVu 12sec Club
Posted: Tue Feb 24, 2009 4:17 pm Post subject: |
you want a digital hvac controller from a 87 gta dont you? and put coloured LED's for temp and fan speed huh it be tricked out. _________________
Posted: Tue Feb 24, 2009 7:14 pm Post subject: |
