Red Bird Member
1991 Pontiac Firebird
Posted: Fri Jan 02, 2009 5:14 pm Post subject: LT1-T5 compatibility |
hey guys, im looking to swap my Lo3 out and was wondering if my T5 would bolt up to an LT1 motor? _________________ 1991 Firebird L03 T-5 |
Red Bird Member
Posted: Fri Jan 02, 2009 9:47 pm Post subject: |
I see, i might be able to get a good deal on an lt1 and wanted to make sure i could use my t5 till i can source a t56 to replace it after the motor swap. it seems i can pick up a iron headed LT1 /ecu for much less than a t56. that huge Hp jump would be worth the swap, id baby it with the T5 its a WC unit so its a lil stronger. _________________ 1991 Firebird L03 T-5 |
Posted: Sat Jan 03, 2009 9:59 am Post subject: |
T5 will be fine until you put sticky tires on it. _________________ A redline a day keeps the carbon away! |
