Chevy 2500 vs. Acura Integra
Jess
Administrator
PostPosted: Tue May 11, 2004 6:01 pm    Post subject: Chevy 2500 vs. Acura Integra Reply with quote
At Bremerton Raceway... Guess who wins? Laughing
Truck vs Integra
'88 Formula
'95 Trans Am - Sold
'88 GTA - Sold
'89 Firebird V6 - Sold
Gibby85
PostPosted: Tue May 11, 2004 11:16 pm    Post subject: Reply with quote
Jeeez, and they aren't even dropping out of the 15's!
www.cardomain.com/id/gibbys85
PonchoTA
PostPosted: Wed May 12, 2004 5:06 am    Post subject: Reply with quote
Let's see, a 3+ ton truck vs. hopped-up import... wonder what kind of mods in each! Shocked
What ever happened to their argument about hp/weight?
Hmmmmmm, cool truck though!
Laughing
PostPosted: Wed May 12, 2004 5:26 am    Post subject: Reply with quote
What do you run Gibby?
85 T/A WS6
1985 Pontiac Trans Am
PostPosted: Wed May 12, 2004 6:51 am    Post subject: Reply with quote
This post reminds me its time to line it up at the strip a PIR....Jesse I need to redeem myself Very Happy
I replaced my EGR valve, It has been stuck open slightly since I bought it.
Runs way cooler now (170 Tstat helps too, runs about 160 on a cool day) and no more codes and detonation. I figured I would replace it since I needed to change out my upper plenum gaskets anyway.
Anyway this Friday is Street Legal and TNT... 25 bucks gets you in.
Im curious with the free mods I have what I will run. Im too heavy to drive though (255), would it make a difference to have my wife drive it instead ? (140)
Last time I punched it on the last yellow...is that a good strategy ?
Don
Jess
Administrator
PostPosted: Wed May 12, 2004 10:54 am    Post subject: Reply with quote
Sounds good Don Very Happy Last time I took ya on the hole shot with my whopping 1.2 reaction time Embarassed
Generally 100 lbs lighter = 1/10 quicker.
Don't think I'll be able to make it to the track this month, but definetly next month!
Gibby85
PostPosted: Fri May 14, 2004 1:04 pm    Post subject: Reply with quote
I can guarentee I will dip into the 14's if I get traction. At worst is very low 15's. If I ever get the money for some headers and to put in this posi, high 14's will be no problem.
PostPosted: Fri May 14, 2004 2:39 pm    Post subject: Reply with quote
Traction problems? Boy let me tell you about traction problems.
Best run of the night last fall in at PIR
(Got this run against a RED car which I beat Very Happy )
60'- 2.154
330'- 6.005
1/8- 9.127
Worst run of the night.
(Against a WHITE car which kicked my ass all night at the track Very Happy )
60'- 2.406
330'- 7.082
1/8- 10.455
And that young Whippersnapper, is traction problems. Razz
PostPosted: Fri May 14, 2004 4:17 pm    Post subject: Reply with quote
Heh you guys are your 15's. My Stock 305 TPI car went 15.2!
Gibby85
PostPosted: Sun May 16, 2004 11:00 pm    Post subject: Reply with quote
See, and my 305 is far from stock. I should dip into the 14's if I can get traction.
Camaro350Z28
PostPosted: Sun May 16, 2004 11:10 pm    Post subject: Reply with quote
You should hit 14's easy, my third gen hit 14.9 and i let off well before the finish line so i coasted through cause i threw my belt off the alt and water pump, kinda sucked and i could never fix the problem so i never got to run again and now my motor is cracked so blah blah ill never know, that was also without warming my tire and my single wheel peel 3.23 hehe
Tim
PostPosted: Mon May 17, 2004 3:33 am    Post subject: Reply with quote
that was also a carbed 350 Wink
PostPosted: Mon May 17, 2004 5:46 am    Post subject: Reply with quote
C'mon Dewey, you know an RV cam can beat a carbed 350 hands down Very Happy
PostPosted: Mon May 17, 2004 6:09 am    Post subject: Reply with quote
although, judging by the aftermath/dents , it does appear that the RV cam was in the lead Rolling Eyes Shocked
although senior tim had been having quite a host of problems IIRC. Gibbs should have his car at cows, we can all see what the RV cam does.
Camaro350Z28
PostPosted: Tue May 18, 2004 12:41 am    Post subject: Reply with quote
thatd be cool id like to see what gibby runs too im sure he does, its too bad i couldnt make it, for one i dont even know what cows is... hmm and second i feel like everyone gonna yell at me for that since i see its post is like 48302 replies and none are me heheh anyway
Tim
PostPosted: Tue May 18, 2004 11:34 am    Post subject: Reply with quote
what are the specs for the 'RV' cam Gibmeister?
PostPosted: Tue May 18, 2004 3:44 pm    Post subject: Reply with quote
Hey Gibster, if you put a trailer hitch on that bad boy you will really let that RV cam shine. Cool
PostPosted: Tue May 18, 2004 8:03 pm    Post subject: Reply with quote
Owned!
PostPosted: Wed May 19, 2004 3:16 am    Post subject: Reply with quote
Owned!
there goes ramrod, the closer.
don't f**k with rodney.
