Jess Administrator
Joined: 24 Nov 2003 Posts: 429 Location: Mount Vernon, WA
Posted: Tue May 11, 2004 6:01 pm Post subject: Chevy 2500 vs. Acura Integra |
At Bremerton Raceway... Guess who wins?
Truck vs Integra _________________ '88 Formula
'95 Trans Am - Sold
'88 GTA - Sold
'89 Firebird V6 - Sold |
Gibby85 Member
Posted: Tue May 11, 2004 11:16 pm Post subject: |
Jeeez, and they aren't even dropping out of the 15's! _________________
PonchoTA Member
Posted: Wed May 12, 2004 5:06 am Post subject: |
Let's see, a 3+ ton truck vs. hopped-up import... wonder what kind of mods in each!
What ever happened to their argument about hp/weight?
Hmmmmmm, cool truck though!
Posted: Wed May 12, 2004 5:26 am Post subject: |
| Gibby85 wrote: | | Jeeez, and they aren't even dropping out of the 15's! |
What do you run Gibby? |
85 T/A WS6 Member
1985 Pontiac Trans Am
Posted: Wed May 12, 2004 6:51 am Post subject: |
This post reminds me its time to line it up at the strip a PIR....Jesse I need to redeem myself
I replaced my EGR valve, It has been stuck open slightly since I bought it.
Runs way cooler now (170 Tstat helps too, runs about 160 on a cool day) and no more codes and detonation. I figured I would replace it since I needed to change out my upper plenum gaskets anyway.
Anyway this Friday is Street Legal and TNT... 25 bucks gets you in.
Im curious with the free mods I have what I will run. Im too heavy to drive though (255), would it make a difference to have my wife drive it instead ? (140)
Last time I punched it on the last yellow...is that a good strategy ?
Don _________________
Jess Administrator
Posted: Wed May 12, 2004 10:54 am Post subject: |
| 85 T/A WS6 wrote: | This post reminds me its time to line it up at the strip a PIR....Jesse I need to redeem myself
Sounds good Don Last time I took ya on the hole shot with my whopping 1.2 reaction time
Generally 100 lbs lighter = 1/10 quicker.
Don't think I'll be able to make it to the track this month, but definetly next month! |
Gibby85 Member
Posted: Fri May 14, 2004 1:04 pm Post subject: |
| Dewey316 wrote: | | Gibby85 wrote: | | Jeeez, and they aren't even dropping out of the 15's! |
I can guarentee I will dip into the 14's if I get traction. At worst is very low 15's. If I ever get the money for some headers and to put in this posi, high 14's will be no problem. _________________
Posted: Fri May 14, 2004 2:39 pm Post subject: |
| Gibby85 wrote: | | Dewey316 wrote: | | Gibby85 wrote: | | Jeeez, and they aren't even dropping out of the 15's! |
I can guarentee I will dip into the 14's if I get traction. At worst is very low 15's. If I ever get the money for some headers and to put in this posi, high 14's will be no problem. |
Traction problems? Boy let me tell you about traction problems.
Best run of the night last fall in at PIR
(Got this run against a RED car which I beat )
60'- 2.154
330'- 6.005
1/8- 9.127
Worst run of the night.
(Against a WHITE car which kicked my ass all night at the track )
60'- 2.406
330'- 7.082
1/8- 10.455
And that young Whippersnapper, is traction problems.  |
Posted: Fri May 14, 2004 4:17 pm Post subject: |
| Heh you guys are your 15's. My Stock 305 TPI car went 15.2! |
Gibby85 Member
Posted: Sun May 16, 2004 11:00 pm Post subject: |
| Twilightoptics wrote: | | Heh you guys are your 15's. My Stock 305 TPI car went 15.2! |
See, and my 305 is far from stock. I should dip into the 14's if I can get traction. _________________
Camaro350Z28 Member
Posted: Sun May 16, 2004 11:10 pm Post subject: |
You should hit 14's easy, my third gen hit 14.9 and i let off well before the finish line so i coasted through cause i threw my belt off the alt and water pump, kinda sucked and i could never fix the problem so i never got to run again and now my motor is cracked so blah blah ill never know, that was also without warming my tire and my single wheel peel 3.23 hehe
Tim |
Posted: Mon May 17, 2004 3:33 am Post subject: |
that was also a carbed 350  |
Posted: Mon May 17, 2004 5:46 am Post subject: |
| Dewey316 wrote: | that was also a carbed 350  |
C'mon Dewey, you know an RV cam can beat a carbed 350 hands down  |
Posted: Mon May 17, 2004 6:09 am Post subject: |
although, judging by the aftermath/dents , it does appear that the RV cam was in the lead
although senior tim had been having quite a host of problems IIRC. Gibbs should have his car at cows, we can all see what the RV cam does. |
Camaro350Z28 Member
Posted: Tue May 18, 2004 12:41 am Post subject: |
thatd be cool id like to see what gibby runs too im sure he does, its too bad i couldnt make it, for one i dont even know what cows is... hmm and second i feel like everyone gonna yell at me for that since i see its post is like 48302 replies and none are me heheh anyway
Tim |
Posted: Tue May 18, 2004 11:34 am Post subject: |
what are the specs for the 'RV' cam Gibmeister?
Posted: Tue May 18, 2004 3:44 pm Post subject: |
Hey Gibster, if you put a trailer hitch on that bad boy you will really let that RV cam shine.  |
Posted: Tue May 18, 2004 8:03 pm Post subject: |
Posted: Wed May 19, 2004 3:16 am Post subject: |
there goes ramrod, the closer.
don't f**k with rodney. |
