Cascade Crew Message Forums
fbird82 New Member
Joined: 31 Oct 2006 Posts: 14 Location: Emmett, Idaho
Posted: Sun Apr 15, 2007 7:26 am Post subject: Just curious |
Does anyone know if the factory installed different coil springs and sway bars for the various engines offered, or did they use the same parts regardless if it was a 2.5L, V6, or V8? Also, where can this kind of info be found? _________________ 82 base model Firebird. GM Performance Parts 350, TH-350, Edelbrock Performer 1406 carb, Performer EPS manifold, Heddman shorty hedders, Hooker cat back exhaust, CEE sfcs, etc... |
Posted: Sun Apr 15, 2007 7:52 am Post subject: |
| There were lots of diffrent spring combinations and sway bar combo's. The V6 springa and V8 springs are diffrent, I know there are also several diffrent rates for the V8 cars, it depended on what year it was, if it was a RS, IROC, WS6, softride, F41. They all had diffrent springs and sway bars. |
fbird82 New Member
Posted: Sun Apr 15, 2007 3:45 pm Post subject: |
How will I know if my particular combination will be strong enough? My car was originally a 4-cylinder and I don't plan to race it, just mostly a cruiser. _________________ 82 base model Firebird. GM Performance Parts 350, TH-350, Edelbrock Performer 1406 carb, Performer EPS manifold, Heddman shorty hedders, Hooker cat back exhaust, CEE sfcs, etc... |
Posted: Sun Apr 15, 2007 4:09 pm Post subject: |
strong enough for what? Depending on what you want from the suspension, it may be right, it may not.
If you want handling with the V8 in there, pick up a set of IROC or WS6 springs, and call it a day. |
