Just curious
fbird82
New Member
PostPosted: Sun Apr 15, 2007 7:26 am    Post subject: Just curious Reply with quote
Does anyone know if the factory installed different coil springs and sway bars for the various engines offered, or did they use the same parts regardless if it was a 2.5L, V6, or V8? Also, where can this kind of info be found?
82 base model Firebird. GM Performance Parts 350, TH-350, Edelbrock Performer 1406 carb, Performer EPS manifold, Heddman shorty hedders, Hooker cat back exhaust, CEE sfcs, etc...
PostPosted: Sun Apr 15, 2007 7:52 am    Post subject: Reply with quote
There were lots of diffrent spring combinations and sway bar combo's. The V6 springa and V8 springs are diffrent, I know there are also several diffrent rates for the V8 cars, it depended on what year it was, if it was a RS, IROC, WS6, softride, F41. They all had diffrent springs and sway bars.
fbird82
New Member
PostPosted: Sun Apr 15, 2007 3:45 pm    Post subject: Reply with quote
How will I know if my particular combination will be strong enough? My car was originally a 4-cylinder and I don't plan to race it, just mostly a cruiser.
PostPosted: Sun Apr 15, 2007 4:09 pm    Post subject: Reply with quote
strong enough for what? Depending on what you want from the suspension, it may be right, it may not.
If you want handling with the V8 in there, pick up a set of IROC or WS6 springs, and call it a day.
